PDA
View Full Version : Mechanical Problems/Vehicle Issues and Fix-it Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 [41] 42 43 44 45 46 47 48 49 50
  1. help please
  2. Possible suspension problems?
  3. i need to vent transmission problem
  4. Trace of gasoline smell from the oil...
  5. How do i get to my deck?
  6. key wouldnt turn WTF!
  7. touching up plastic
  8. can't reset Maintenance Required Light
  9. jacked emblems
  10. Wtf Battery Probs
  11. Need Power!!
  12. Side Panel
  13. Array of problems
  14. Won't start in Extreme Cold
  15. Has anyone successfully used a TSB to fix 2nd gear problems?
  16. Trip from hell
  17. where to get this bulb?
  18. light is messed up
  19. Driver Seat Loose
  20. Front Bumper Crack/Dent?
  21. 10,000 mile maintanece required light?
  22. shifter issues
  23. Clicking/Rattling???
  24. i got a dent!!
  25. Dealed says tranny is "supposed" to JERK when cold!
  26. info the difference between a 2k1 and a 2k3 gauge cluster
  27. OEM alarm died???
  28. Shock-not as in suspension
  29. Hesitation/miss while cruising
  30. Possilbe Hydrolock???
  31. clutch make crackling sounds...
  32. Fogged Headlights!!!!!!!!Help!
  33. Engine dies, BIG PROBLEMS!!
  34. Starter motor overrun(I think) when cold
  35. altenator proble...i think
  36. Choking in 2nd gear!!!!
  37. HELP...Please someone
  38. Worse than before
  39. Yay, Rattles!
  40. cel light blinks...
  41. DRL not working with weired noise
  42. weird occurance
  43. stock shift knob twists around
  44. tranny slipping
  45. 911 Need Help From Everyone
  46. Omg...i Need All The Help I Can Get
  47. CEL doing donuts in snow
  48. Altezza light problem
  49. Cruise Control and Horn not Working. Please Advise. thx
  50. tyc problems >>>help
  51. My car is falling apart
  52. Iridium or another type of Spark Plug
  53. How Do I Fix It???
  54. Clutch pedal problem
  55. Heater not working!!
  56. Maitenence required-----Oil Change ?
  57. Car just turned off
  58. Cold Air Intake!!!! Help!!!
  59. oil drain plug
  60. Cancel extended warranty?
  61. Dealership responce to my tranny problem
  62. Dropped a socket in my engine/frame :(
  63. Buzzing noise for engine compartment or tranny.
  64. Numerous Problems With CAR!!
  65. Car shakes when i hit the pedal
  66. antenna prob
  67. More tranny problems
  68. rear brake
  69. Rattle at 3000 RPM HELP!!!
  70. HELP with aftermath of hydrolock!!! weird sounds!!
  71. Differences in bumpers and colors between years (01-03)
  72. Headlighrs Fogging
  73. Rock hit windshield
  74. Help!
  75. brake rotors...
  76. Are headlights covered under warranty?
  77. seatbelts keep locking
  78. Screwed by Honda
  79. Got an axle prob and need answers
  80. Noise from engine compartment
  81. VIPER 790XV with AUX for Sunroof Opening
  82. trans / clutch problem
  83. Manual tranny problem
  84. Help Plz!!!!
  85. Door Locks?!?!?
  86. 2inch drop 2.5 piping
  87. Factory door locks????
  88. A bent condensor = big prollem?
  89. Tranny is completely gone...
  90. Possible strut problem?
  91. Why Does My Whole Car Shake....?
  92. Someone Help Asap
  93. Power Steering Fluid Replacement..
  94. scratchy sound by wheel...
  95. question / washer fluid
  96. Ticking Engine
  97. HELP me out guys!!!
  98. Frozen Locks
  99. "MAINT REQ"light, cant reset
  100. spider cracks in OEM rear bumper
  101. power loss?
  102. TSB's in Canada
  103. broken turn signals!!!
  104. power steering fluid replacement
  105. Brake and related problem?
  106. taking door panel off
  107. '03 has a hard time starting
  108. Starting issues
  109. Grrr at dealership.
  110. Speedo not working after installed headers
  111. Rattling noise from passenger side?
  112. How often to clean your intake
  113. Warrenty almost due - how do i collect?
  114. Battery Issues...
  115. problem with leather
  116. headlights dim
  117. 120 miles and a steering issue
  118. Clutch pedal or linkage creaking.
  119. malfunction indicator lamp + $325??? WTF???
  120. BAD Paint chip!!!!!
  121. reversing speedometer?
  122. Noise in second gear
  123. Driver Side Mirror
  124. Air filter
  125. wheel well bent
  126. exhaust rattling on rainy days?
  127. noise coming from engine
  128. Suspension squeaking...need opinions...
  129. Has anyone had this problem
  130. Whats wrong?
  131. will my endlinks break
  132. My Windsheild Is Cracked!!!
  133. Air/Fuel Gauge
  134. help" the "CHECK" light in the gauage
  135. Cold weather issues...
  136. Automatic Transmission..
  137. Veering Left on Freeway??
  138. automatic door lock??
  139. sticking trunk release
  140. wet rear carpet??
  141. Has anyone changed the alternator yet ?
  142. AEM CAI + Water = WEIRD NOISE
  143. Does anyone find that Honda's recommended intervals are way too long?
  144. My speedometer jumped by 25mph
  145. anyone else have this problem?(headlights)
  146. Door protection crap
  147. car vibrating and shit
  148. SRS light
  149. Need some helps from an Alarm Pro!
  150. Axle Problems anyone
  151. My Bumper Got hit! When It was Parked!
  152. auto tranny
  153. plastic burning smell
  154. Exhaust Back Pressure
  155. is your lite up?????
  156. ****in Maintenence light...
  157. is it okey to take the Spring off on muffler?
  158. tps sensor
  159. need help
  160. Need help with OEM Cd player
  161. CEL after 4 days of owning my 04'
  162. Do you lose more gas with a after market exhaust?
  163. i'm at the dealer right now...
  164. Projector Headlight
  165. hesitating
  166. Help need your advice, problems with car and Honda
  167. Which tree do I go barking up?
  168. Dip in my power band?
  169. Auto Tranny Vibration?
  170. Alignment?
  171. Loud when Wet
  172. engine starting problem
  173. Strong washer fluid smell through the vents.
  174. FACTORY RECALL on fuel line clamp
  175. CD Eaten!!!
  176. How to prevent Misfiring
  177. weird high pitched noise when accelerating
  178. Warranty and Dealer Question after an accident
  179. Horrible noise when the wheel is turned left
  180. gearing weird?
  181. High pitch whine while speeding/windy.
  182. Driver Seat Belt...
  183. Grinding brakes & related issue...
  184. i am very lazy and forgetful
  185. Water Noise / Liquid Sound on Acceleration
  186. my civic ?
  187. 2003 civic wont chirp
  188. DIY Transmission Flush...f
  189. WEIRD problem
  190. 10k mile service! how much $
  191. Neuspeed Race...Does it matter
  192. Car stumbles upon cold startup...
  193. Maint. Req'd light at 16,200 miles
  194. Intake concerns
  195. Cruise Control doesn't work when headlights on
  196. Brake Squealing.. another question too..
  197. muffler backfire
  198. Slow Accleration and Low Gas Mileage
  199. removing wing
  200. Please help! Engine revs when car is started!
  201. my equipment got exchanged!!!
  202. dash shape
  203. Stink burning smell
  204. HELP! Condensation in Cleared Headlights!
  205. MPG what is the deal?
  206. a/c question
  207. More fun shifting...
  208. piece of sh*t
  209. that vibration...
  210. My car was hit at honda.
  211. massive recalls from honda...
  212. problem with civic and ex decals
  213. water on the floor
  214. Is this the headlight wiring harness?
  215. strange exhaust problem
  216. Helllllp!!!!!!!!!
  217. A Huge Clunk Noise When Braking
  218. PLEASE help, did I FCUK UP???
  219. Cruise Control Light Doesnt Work
  220. At stop....
  221. Tsudo owners??
  222. trunk problems
  223. I Need Help
  224. rims rubbing on calipers
  225. rattling
  226. Hrm. . This is new..
  227. How do I fix this "special" rattle?
  228. **** Honda And Their Bullshit
  229. Transmission
  230. Strange startup problem
  231. engine trouble
  232. Erratic idling
  233. Ignition Switch Recall
  234. Antenna Problem
  235. cranking or knocking noise
  236. Help! Vandals And Spray Paint!!
  237. flashing MAINTAINENCE REQUIRED
  238. Engine Swap Problem
  239. Picked up my new 04 coupe today, and the CD player has problems?
  240. problem...
  241. Help !!!
  242. oil level question
  243. Question about painting
  244. My list of problems.....
  245. Just had another weird problem?
  246. maintenence reqd ????
  247. Idle Air Control Valve? (Where)
  248. enging makin weired sound
  249. Regarding the 01 Stalling Issues
  250. Moonroof shattered on the 60fwy
