tyc problems >>>help
Old Jan 14, 2004
acidbaby's Avatar
The Beez Kneez
ok i installed my tyc projectors today and i was driving and the lows went out.
i am currently running eurodesigns 100w bulbs. which is what i was using when i had my matrix halo projectors. i never had one problem with the bulb at all. i was wondering if ne one might have had the same problem? or if someone might have an idea of what might be wrong!!!!! please i cant drive my car like this. plus i share it with my wife she will kill me if she finds out that there is yet another problem. oh and i checked the fuse to make shure.
they both went out at the same time it was weird.
fixed http://www.7thgencivic.com/forums/sh...66#post1698866 fixed sorry guys
Old Jan 14, 2004
acidbaby's Avatar
The Beez Kneez
wow that was post 666 hehe
Old Jan 14, 2004
acidbaby's Avatar
The Beez Kneez
wtf noone can help me? lease:
Old Jan 16, 2004
dru106's Avatar
ThE CoRRupToR
If i were u i would go back to stock...jmo
Old Jan 17, 2004
civic02ex's Avatar
got banned
civic02ex is an unknown quantity at this point
Unfortunately, I can't help you. Im about to install my TYC lights so that forum you gave helped me out. However, I work in a electronic shop for the government and I must say that the light bulb harnesses themselves should already be wired to ground, power, and switch. Im not getting a picture of running an extra wire to the projectors without it looking "messy." But if you were to run the ground wire, do not run it to no freakin negative terminal. Thats just tearing up your whole clean engine bay look, but instead just drill a small terminal hooked to a self tapper screw somewhere hidden in the engine bay. Please keep me posted or pm if you have better luck with this. Thanks and sorry for not helping out much.
Old Jan 19, 2004
bluericeburna2k2's Avatar
bluericeburna2k2 will become famous soon enoughbluericeburna2k2 will become famous soon enough
acidbaby: did u clean off ur bulbs with some isopropyl alcohol before plugging them in? oil from your hands might have been on the bulb causing them to heat up and burn out. or maybe when u were installing the bulbs you accidentally scratched the glass envelope when inserting the bulbs into the socket. also make sure u secure the rubber housing behind the socket to prevent water from entering the housing. i dont know what else to tell you... hope everything works out. Peace
Old Jan 19, 2004
acidbaby's Avatar
The Beez Kneez
they both blew out at the same time. same problem as the link i posted twice. i know how to install the bulbs themselves
Old Jan 19, 2004
hmmm ive noticed that u said 100w. the stock h4's were 55/60w. so shouldnt ur new h7's be 55w? too much strain on the factory harness possibly?
my2k1vic
Jan 8, 2002 08:31 PM
Professional
Jan 6, 2002 11:42 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
ademarco6
Dec 28, 2001 12:25 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
