Yay, Rattles!
Old Jan 16, 2004
chknmnky's Avatar
chknmnky will become famous soon enough
Yay, Rattles!
I thought I knew how to work on a car well. I've had enough experience with engine swaps, rebuilds, and other stuff. So I figured I could add a few extra things to my nice new pretty civic. When installing my cat-back I stripped two of the bolts on the catalytic converter. I tried using a tap and die kit on it. It just made the bolts worse. So now I have only one bolt holding my exhaust pipe to the cat and it sounds like shtuff. I figured why stop there, I went and put a injen cai in, sure enough I confused lefty loosey with righty tighty and stripped a bolt on the inside . I cant get it out worth a $%#, and my cai is loosely hanging and tapping against my wheel well. It sounds fine when I'm blaring down a highway, but you don't want to be in my car when I idle, ugh.
Old Jan 16, 2004
Mr.Modify's Avatar
gj
Old Jan 19, 2004
VTEC01EX's Avatar
VTEC01EX is an unknown quantity at this point
That's funny, I installed a CAI, then swapped to an SRI, then installed a catback... then removed all of it, all without incident. And I don't know anything about cars!
Old Jan 20, 2004
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
you have the same problem that I have with stripping screws. Somehow I striped one of the screws holding the rear struts when I was trying to install a rear strut bar, and messed the threads up when trying to remove my strut bar to do some cleaning. The die/cast kit worked well on all though so I got lucky.
Old Jan 21, 2004
solar's Avatar
solar is an unknown quantity at this point
No offence here, but how did you get away with engine swaps and re-builds if you don't know which way to turn the bolt to loosen? (kidding ) I know sometimes I would get confused if I was working on something upside down, but you really had to give it hell to strip or break the bolt. I used to hate drilling out broke off bolts and re-tapping them, it can be a real bitch, good luck.
Old Jan 22, 2004
chknmnky's Avatar
Thanks, I appreciate the luck. Meinike offered to weld the exhaust to the cat but instead I just bought a hi-flow cat. Might as well since I'm trying to squeeze out horsepower.
Old Jan 23, 2004
modoman's Avatar
^better squeeze harder than that...
mistahlorax13
21
Nov 18, 2015 12:47 PM
rovafa2002
Sep 28, 2015 06:57 PM
fvckbg
Sep 8, 2015 09:55 PM
dantheman42
Sep 4, 2015 01:10 PM
Yazan93
Jul 14, 2015 08:56 PM
