Cruise Control Light Doesnt Work
MY CRUISE CONTROL LIGHT DOESNT WORK
I RECENTLY DISCOVERED THIS.
I INSTALLED A STEREO IN ABOUT A MONTH AGO AND DONT KNOW IF I DID SOMETHING WRONG.
PLEASE HELP!!!
(I THINK THAT IS THE ONLY LIGHT ON THE DASH THAT DOESNT WORK)
PLEASE HELP!!!
That light should be on a fuse with at least a few other items... if it's the only thing that's out, I'd say it might just be either a bad connection to that light, or it might actually be burned out. BTW - you might want to check that LED on your keyboard that indicates your caps lock is turned on.
Does the switch work? If so, it's not a fuse problem - it's the little bulb in the switch that burned out. I replaced this bulb on my old Accord several months ago. Just pop the whole switch out from the dash, and a little bulb can be replaced from the rear. The bulb has a little slot for a small screw driver, just turn it 1/8th of a turn and it pops out.
Thing that sucks is that it costs something like $9.00 for this little tiny bulb.
Abercrombie and Fitch
OHH im sorry man...... its just your light thats burnt out!! yeah i had the same prob.. it works and everything....... its not a fuse.. and yes mine burnt out....... just replace it and your set man
ORskier
May 3, 2015 12:54 PM
honkeydonkey
Electrical
Apr 26, 2015 08:27 PM
cooldan1
Apr 23, 2015 10:49 AM
SSMatey
Apr 13, 2015 06:09 PM
