help" the "CHECK" light in the gauage
Old Dec 3, 2003
Tojo's Avatar
=) Im Bi-Sexual <3
Tojo is an unknown quantity at this point
Question help" the "CHECK" light in the gauage
right next tot he battery logo where the MAINT lights r ...
i gas'ed up my tank lik 1-2 day(s) ago. I remember poppin my hood in the morning, didnt touch anything . Afternoon the "check" light appeared.. so i got all scared n **** what tf??
i remember feelin a tremble from my car when i was braking..
after 2hrs i decided to drive over to the dealer..
everythign went normal (wit the car)
i drove int he service garage that said its a bit late to have it check now
they asked me when was ur last time u did a service
he said u' prolly need a service
i asked what kind? he said he doesn kno yet./.
did the check light appear on u??
shud i bring my car to the dealer again 2m? i kno they gonna charge me a lot!!!
btw the light is gone after i out of the honda dealer place
its been on for 4-5hrs
i also dropped my car lik 3weeks ago (wit springs.. duno if that ffect the car or not?)
thanks!
Old Dec 3, 2003
Tojo's Avatar
=) Im Bi-Sexual <3
Question when the "CHECK" light appears?
heres my other thread on the same question
http://www.7thgencivic.com/forums/sh...hreadid=128105
i read the driver's booklet
it says if the check sign disappear after 3 road trip then its ok?
is that tru that i dunt have to go back 2 dealer then?
Old Dec 3, 2003
Project2k2's Avatar
well, the same thing happend to me, but that was when I hit 10k miles. Maybe this is your situation. It's just Honda's way of getting you into the dealership for a check up (IE spend your money). If your are not at the 10k mark, then something is wrong? PS fluid? Radiator Fluid? Oil? Any of these things can cause this to happen....?
Old Dec 3, 2003
ImPulse's Avatar
your car is going to explode =\
Old Dec 3, 2003
Tojo's Avatar
=) Im Bi-Sexual <3
i jus had a full service check when i went to change my oil
lik 2 weeks ago
44k milage
Old Dec 4, 2003
Boiler_Room's Avatar
Boiler_Room is on a distinguished road
Those lights come on at certain mileage intervals. Your car is probably just fine. Honda does it so they can make more money off you. It's just a scheme of theirs.
Old Dec 4, 2003
Tojo's Avatar
=) Im Bi-Sexual <3
alrigt
thanks!!
Old Dec 8, 2003
smoke4's Avatar
The Dude
isn't there a way to turn it off w/o going to dealer? can someone tell me how to do it?
"1. My "Main't Req" (Maintenance Required) light blinks / is constantly on?
Push the trip odometer reset, turn the key until the dash lights all come on (don't start it)
Hold it until the Maint Reqd. Light shuts off.
Turn the key off and take your finger off the button.
(Thank you Boilermaker1)"
Sticky's are great.
Old Dec 8, 2003
flotsamm's Avatar
CEL and MIL are different. MIL is for reminding you that your car should be brought in for maintenance. The CEL is if there is a problem, like a loose gas cap.
Old Dec 9, 2003
Tojo's Avatar
=) Im Bi-Sexual <3
the light is gone but shud i still go n check it out?
Old Dec 9, 2003
SGda's Avatar
SGda is an unknown quantity at this point
Re: help" the "CHECK" light in the gauage
thanks!
just checking, when the light comes out, does your car jerk?
my 'check engine' light went bonkers on two occassions, and in both occassions, the car will start to jerk first, before the light comes on. in the first occassion, the problem disappeared when i refilled.
however, on the 2nd occassion, the jerking and light refuse to go away. i went back to my local dealer, and they diagnosed the problem as a faulty EGR. I had it replaced, and the check engine light disappeared, but the car is still not as smooth as before, during acceleration.
Old Dec 9, 2003
flotsamm's Avatar
If its running fine, then I wouldnt take it in. I would however be curious what code got stored.. maybe see if youcan find someone with a code scanner and pull the code from the computer.
Old Dec 9, 2003
Tojo's Avatar
=) Im Bi-Sexual <3
ui thoink it jerked a lil
MyCivic
Electrical
Oct 28, 2021 11:06 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
Blazz
May 25, 2015 10:56 PM
werdnahall
May 17, 2015 11:37 AM
davidarenberg
May 16, 2015 08:45 AM
