DRL not working with weired noise
Old Jan 16, 2004
orion_squall's Avatar
Hi,
so it has been -30 C this whole week and now my car has a problem...
The right side of Day time Running Light will not turn on when I turn my key to ignition II. Also I can hear "ZiZiZiiZiiZZZzzzziiii" noise.
When the key is at ignition III, the engine starts but the right headlight is not running at "Day Time Running Light" and the gauge shows yellow "DRL". And I still hear "ZiZiZiiZiiZZZzzzziiii" noise.
However, when I turn the headlight to fully driving light (like at night). both headlights will turn on and the noise disappeared.
Can some explain to me what it wrong with the car? and obviously something is wrong with the Day Time Running Light...but why the noise?? And since both headlights can turn on at fully driving condtion (night) the problem is not on the bolbs...
can someone give me suggestions and helps.
thanks
Old Jan 19, 2004
rpannick's Avatar
rpannick is an unknown quantity at this point
I had the same problem on my 2001 Acura 1.7EL. The dealer found the DRL Module at Fault. It was replaced under warranty and then problem was resolved.
Old Jan 19, 2004
now the problem just disappeared, today I turn on to ignition II and everything is working...
since I am unable to point out the problem with everything working nowfine, what should I say to Honda? or should I leave it?
thanks
Old Jan 20, 2004
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
i thought the DRL's dont turn on until you shift gears....
civicns
May 8, 2015 09:49 PM
Ashley Farr
May 7, 2015 05:01 PM
ORskier
May 3, 2015 12:54 PM
edgenet
May 2, 2015 08:00 PM
PimpBot5000
Nov 26, 2001 07:15 PM
