Speedo not working after installed headers
Old Dec 16, 2003
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
I installed a set of headers on my car yesterday which removes the cat. So my check engine light is on. I installed a CapsersElectronics o2 simulator today to remove it but for some reason it doesnt work. Also I noticed my little battery light is on along with the check engine light. I noticed too that my speedometer is not working everything else is cool except for the speedometer and the battery light. Anybody know whats causing this?
Old Dec 17, 2003
NoFriends's Avatar
I like ruining your threads.
hmm a set of headers you say... you must have bought that uber-rare v8 civic that been rumored to exist.
Old Dec 17, 2003
robbclark1's Avatar
Retired suspension supermod.
did you splice the right wires? did you reset the ECU?
Old Dec 17, 2003
Green Civic's Avatar
What header did you install?
Old Dec 17, 2003
XSRCivic's Avatar
wires didnt need to be spliced. its a plug-n-play o2 sim. Tried searching on how to reset the ecu but no one gives clear instructions.
Old Dec 17, 2003
robbclark1's Avatar
un do the positive cable from the battery, wait ten minutes, put back on, and that should reset the ECU. Or you can pull the fuse to ECU. I suggest doing the battery thing.
Old Dec 17, 2003
FuzzBeC00L's Avatar
Fuzzy Boy
Is that going to happen when i put my KAMIKAZE HEADERS hi-temp black ones let me know guys then I will just send them back
Old Dec 23, 2003
XSRCivic's Avatar
Update on the speedo not working/batt light on. Checked fuse for alterntor. It was blown. I replaced the fuse and speedo works now and batt light is off. Only thing left is the check engine light. Will have to contact CapsersElectronics to figure the problem.. Laters
Old Dec 23, 2003
robbclark1's Avatar
did you reset the ECU? The check engine light will come on usually if you install an intake or non carb legal header because of the amount of air flow. Reset the ECU first and see if the light stays off. If it doesn't then take it in to see what code you are throwing.
ORskier
May 3, 2015 12:54 PM
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
alexkharden
Apr 23, 2015 07:13 PM
