Starter motor overrun(I think) when cold
Old Jan 19, 2004
Polamnus's Avatar
Polamnus is an unknown quantity at this point
Question Starter motor overrun(I think) when cold
I've got a 03 EX manual. It's been cold lately in central NY, very cold(-15F one morning last week). I've noticed that whenever it gets very cold like this(20F or less, roughly), my starter motor sounds like it's running too long after I stop turning the key. It's like the gear that engages the flywheel is sticking in place a second or two too long after the engine has turned over. The indication of this is a whine after I stop turning the key that increases sharply in pitch as the engine roars to life. After 1-2 seconds it totally stops.
Is this normal, or should I be calling the dealer?
Thanks for any advice,
Pol
Old Jan 19, 2004
flotsamm's Avatar
Sounds like the starter solenoid isnt drawing back the gear quick enough before the engine fires up. Could be a sticking solenoid.. if its not grinding and starts up fine, it might not be worth fixing yet.
Old Jan 19, 2004
malice29r's Avatar
malice29r is an unknown quantity at this point
Mine does that too!
I posted about this a few months back..but nobody knew what it could be - i always assumed it was the alternator, but this starter motor thing sounds like it could definetly be it..
Mine sounds almost exactly like the whine our trannys make when going fast in reverse..then it dissappears after about a second or less..
If you find out what it really is then plleeeease post an update back here!
Old Jan 20, 2004
AdamYYZ's Avatar
AdamYYZ is an unknown quantity at this point
Im pretty sure alot of cars do that in the extreme cold. I know mine does. The other week it was so cold I let the clutch out and it lagged behind my foot about a second.
Old Jan 20, 2004
greggdogg's Avatar
greggdogg is an unknown quantity at this point
I was in Central NY the other day and had the exact same problem. Keep the gas tank full, keep it full of antifreeze and you should be OK.
Old Jan 21, 2004
cdub604's Avatar
cdub604 is an unknown quantity at this point
ya i live in calgary canada and mine did that when it was like -30 a couple times too
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
mistermenphis22
Jul 13, 2015 04:43 PM
JUNITO
Jul 9, 2015 08:36 PM
671civicLX
Jul 9, 2015 03:22 PM
Supramk3
May 11, 2015 07:55 PM
