Car stumbles upon cold startup...
Old Nov 9, 2003
MangoEX's Avatar
Just Be
MangoEX should not be trusted
In the morning, when i start up my 02 ex auto, the engine cranks over fine, but RIGHT before it completes its cranking cycle, it stumbles before turning over... like its choking. its done this since new, is this normal with you guys? Only does it on a codld start in the mornings when i leave for work.
Old Nov 9, 2003
I would turn it to the on position, wait for a few beeps, then turn to start. Mine used to do what you're saying, but not anymore for the most part. It builds the fuel pressure when you do that.
Old Nov 10, 2003
Voiceofid's Avatar
End Bringer
yep, turning on your key for a bit will put pressure back into the fuel lines. cold cranks require a bit more fuel, and more fuel = needs more pressure
Old Nov 11, 2003
MangoEX's Avatar
Just Be
sounds good, i will try it
Old Nov 16, 2003
iceman's Avatar
--< GripSpeed Member >--
hell yeah...mine does that to...but it keeps on shakin for bout a couple secs..and then everything is fine...just recently the check engine light came on...i had someone do a diagnostic..and it said my engine was misfiring and one of the coils arent gettin enought eletricity
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
Tedverseti
Apr 23, 2020 01:45 PM
rcolosi
Apr 29, 2015 07:48 PM
Hobby2K
Bolt-on Engine Performance
Nov 9, 2001 04:08 PM
SneakerPimp
Nov 4, 2001 01:12 PM
