Exhaust Back Pressure
I recently put a Greddy EVO2 Cat Back Exhaust on my 2003 CiVic EX. I am actually losing horsepower because of the lack of back pressure. It also rattles a little. It was up on the lift the other day and there is more than an inch clearence on the pipe. three people where shaking and pushing on it and could not get it to hit the underbody. Please help Headache gettin worse?
damn green beat me to it. Yeah you more than likely have a leak somewhere. And the rattling is either normal or it is hitting your bumper.
if you still have a cat, there should be no problem with loss of back pressure through the muffler.
also, make sure your not hitting the body with the pipe, that kind of banging could trigger knock retard and cost you your power-
the Evo II makes contact with the underbody right underneath the shifter. I put 4 layers of heat resistant fabric between the pipe and the car, and I have no more rattles. I'm sure that's your problem.
I need TP for my bunghole
Yeah it could be touching the heat shield
As for the back pressure. yyou bourth an exhaust to getter flow. So the HP's will kick in at a higher rpm. If you are on a freeway or highway you can mash on the pedal and get better rpm/power response.
People have this same complaint with intakes too.
I've heard that adding a universal silencer will also give backpressure while lowering the sound. I might be trying one for my rear-section.
dinsum
May 28, 2015 09:30 PM
Supramk3
May 11, 2015 07:55 PM
crowtoo
May 11, 2015 06:50 PM
