headlights dim
Old Dec 13, 2003
tdiddy's Avatar
tdiddy is an unknown quantity at this point
headlights dim
OK i did search this. My headlights dim when my fans kick in. And not just a little its almost like switching my brights on and off. This doesnt seam normal, or do i need a new battery
Old Dec 14, 2003
honda04civic's Avatar
honda04civic is an unknown quantity at this point
My headlights dim when I have my music up and stop giving her gas, but brightens up as soon as I press the pedal.
Old Dec 14, 2003
That fan takes up a huge amount of power, especially when the A/C is on. This is normal. If you have a voltmeter, you'll see that the alternator actually turns off most of the time and only comes on when something is drawing a big load. Most of the time you'll be running on 12V. So if you're cruising and the fan comes on, voltage will drop way below 12 and after that the alternator will kick in to bump up the voltage to 14. It's normal cause our alternators and charging system suck.
Old Dec 14, 2003
civicvtec1ps's Avatar
Search and Learn
I wouldnt worry about, That is normal.
Old Dec 16, 2003
JCiv03's Avatar
yup its normal, it also dims when you roll down the windows
IronFist
Sep 25, 2015 07:13 PM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
junkyardguy
Sep 2, 2015 06:07 PM
msaeger
Sep 2, 2015 08:47 AM
