Won't start in Extreme Cold
Old Jan 29, 2004
thedude's Avatar
thedude is an unknown quantity at this point
Angry Won't start in Extreme Cold
I have an '01 Si Coupe (Canadian model). It's extremely cold right now -40ish (-50ish with the wind).
Car won't start - battery looks fine, when I turn it over, dashboard lights come on, but the engine doesn't turn over - it just makes a rapid clicking sound. It normally starts fine in the cold, but it's usually at least 20 degrees warmer than this.
I had to leave it unplugged one night, but then plugged it in the next day, it has been plugged in for over a day (I've checked the outlet I'm plugged into - it works).
Any ideas - is it possible that my block heater isn't working, can the imobilizer freeze up? Should I get it towed to the dealer and get it checked out?
thanks.
Old Jan 29, 2004
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Battery is too cold. The battery in the civic is small, as it is. Batteries do not like cold. In THAT weather, I'd think about an optima battery. They are designed to endure a lot of extremes.
Extreme cold is hard on anything. Just try starting a diesel in that cold.
Old Jan 29, 2004
Gecko's Avatar
same temperature lately here.......at night i have it in the garage but it sits outside all day while i am in work for 8 hours. it was plugged in and it started fine.....only did that whinning sound for a second....may be the block heater on yours
Old Jan 29, 2004
Ronin's Avatar
Ronin is an unknown quantity at this point
Very easy to check if block heater is working -- it will start making clicking or humming sounds once you plug it in, you can't miss it. Have someone plug or unplug the heater and see if the sound starts or stops.
Engine not turning over can be several things: frozen battery like Tinman said, or frozen gasline. Do you put in gasline anti-freeze with every other fill-up or so (highly recommended in your type of weather)? If not, that could be it.
I used to live in Ottawa Canada, so I know all about cold weather issues.
Old Jan 29, 2004
civic01vtec's Avatar
put a battery charger on the battery or jump it.......i've had to do that a few times with our heavy equipment.
Old Jan 30, 2004
My car really struggles to start up. I'm thinking it's the battery as well.
Old Jan 30, 2004
astropunk's Avatar
astropunk is an unknown quantity at this point
i had the same problem...
i think was b/c i dindt' have much gas in the tank.. gas might have been frozen
Old Oct 11, 2022
gothicsunrader's Avatar
gothicsunrader is an unknown quantity at this point
Re: Won't start in Extreme Cold
Try warming your key if it is frozen. I found since I left my keys in the car, the chip in the key would malfunction and the immobilizer would not let the car start.
Tedverseti
Apr 23, 2020 01:45 PM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
black2k1vtec
Dec 6, 2001 09:49 PM
supercivic01
South
Nov 30, 2001 11:27 AM
