Dealed says tranny is "supposed" to JERK when cold!
I have a 2002 Acura EL ( Basically , a luxury Civic In Canada); With an automatic transmission. It now has around 50000kms, ( 30000 miles); and When it was new, even on the coldest morning, I never ever had problems with the transmission. Now, when it's cold, and I am trying to get out of the driveway, the engine will rev up to 3000, but the car is not moving! , and after a few seconds, BOOM, the car jerks forward. And sometimes, on really cold mornings, when I move the selector from P to D, there is a loud THUD!!; Anyways, the dealer says that his does the same thing, but I don't care what HIS does!!!! When I bought the car new, it did not do that! So under warranty, should whatever this is be repaired? Or is there a clause in the warranty that states that this is NORMAL?????????
Any suggestions would be appreciated.
Thanks
Thanks
go back to the dealer and DEMAND that someone looks at your car. you know and they know its not normal for a car to do that so tell them to fix it before your warranty is expired.
what are you still reading this for... GO NOW YOU FOOL!!!
< My future wife.
GO NOW U FOOL!!!!!!!!!!!
they just want u to keep fvcking up ur car with that problem so that the thing isn't driveable once ur warranty is up and then whoops looks like a $2500 repair! DARN!
Well, the noises and thuds you hear are guite normal for a honda auto imo. If you ever notice other honda drivers in parking lots, listen for when they shift out of park and so forth. You will hear noises. Yes, it is going to be worse when it is really cold.
Pretty much listen to any other car manufacturer's autos shift from park and between the gears and you won't hear sheit. It's a honda thing....Now, the tranny slipping, it shouldn't be doing that...
My tranny is fine in the cold. Makes a little noise switching, but nothing big. It seems to slip more in warm weather between 1st and 2nd. When the car is cold, it should shift faster.
I don't know, 3000 is a little high. On the coldest mornings, my car only idles at 1500 max, no higher, and it gradually evens out to 500-750 as it warms up.
As for the bumps, it sounds like something is wrong there. I agree with Da1lyDr1ver, go and see if someone can look at it. If not the dealer, try somewhere else.
May 4, 2016 07:14 AM
mokkush
Jul 14, 2015 04:05 PM
Jul 14, 2015 03:39 PM
NoobyKid
Jul 13, 2015 07:53 AM
