Need help with OEM Cd player
Old Nov 22, 2003
Samari's Avatar
I cant get it to turn on. I took it out to try to install another cd player but i didnt like it so I put the OEM player back in and it wont turn on. It is plugged in and I made sure of it. I checked the radio fuse and its not blown. My demobilizor wont work now either. Can anyone give me some ideas. Ive done this before and the cd player turned right now when i put it back in, but now its not doing it.
Old Nov 23, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
oem deck requires a code everytime u power up the deck, so for instance once u unplug the deck, the next time u power up the deck u need the code in order to power the deck...the code should be in ur manual, if not call ur local honda dealer
Old Nov 23, 2003
Samari's Avatar
it wont even turn on, so i cant put the code in. thats the problem.
Old Nov 23, 2003
make sure u have the right harness/connector...press the **** once it should turn on and ask for code
Old Nov 23, 2003
obtix's Avatar
www.AbsouluteDriven.com
obtix is an unknown quantity at this point
If you checked the fuse already make sure no wires are crossed out.... Find the 2 powers and the ground on the back of the deck and plug it right on the battery just to make sure you didnt fry your deck. (or any 12v source)
Old Nov 23, 2003
You have an 01 or up civic right? It should be simple plug and play. What do you mean the new deck didn't work? That's strange.
Old Nov 24, 2003
Samari's Avatar
my oem deck wont work. I plugged it in and it wont even turn on when i hit the button, so i cant put in the code. also the demobilizer doesnt work either.
Old Nov 24, 2003
Samari's Avatar
what do you mean by making sure no wires are crossed out?
Old Nov 24, 2003
Well, if it doesn't work when you plug it in, then it's broken. Are you sure you didn't blow a fuse somewhere? Check them all under the hood and under the steering wheel. Particularly the backup fuse underhood. Try to find another 7thgen you can test your deck on.
Old Nov 24, 2003
Samari's Avatar
i did, but i didnt check the backup fuses. what backup fuses anyways? also why woudl the keyless entry also not be working?
Old Nov 24, 2003
Samari's Avatar
Hey gearbox, thanks for the help. I checked the backup fuse and thats what it was. never thought a backup fuse would be the problem, anyways thanks again.
Old Nov 24, 2003
No problem. Funny how the backup fuse goes out and still causes tons of stuff not to work.
UltraHDGames
Jun 8, 2016 05:16 PM
thatcham
Sep 30, 2015 08:28 AM
Cam Diaz
Sep 28, 2015 08:34 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
lolhowell
Photography & Videography
Sep 11, 2015 05:09 PM
