PDA
View Full Version : Mechanical Problems/Vehicle Issues and Fix-it Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 [36] 37 38 39 40 41 42 43 44 45 46 47 48 49 50
  1. And the problems just keep coming...
  2. Anyone with an automatic tranny ever experience this?
  3. Radio station changes by itself....
  4. HELP! engine malfunction light on.
  5. weird now im pissed/upset
  6. loud noise when driving over 75 mph
  7. Whats wrong with my A/C
  8. Clutch and shifter problems
  9. Screeching noise
  10. Car Not Wanting To Run
  11. One Click in clutch pedal when pressing
  12. whats the part number??
  13. Left axle leaking
  14. required maintainace light
  15. Gas Cap Cover Wont Open Help A.s.ap.
  16. no reverse gear?
  17. Air Condition Problem
  18. Pulled codes and need some help!!
  19. noise somewhere in the car
  20. roaring?
  21. Auto Tranny Problem
  22. Grinding Noise in the Rain Only
  23. TSB Question
  24. clutch problems
  25. help cooling problem (searched)
  26. Power window question...
  27. Brake Light on
  28. Help a newb with a code
  29. HELP: My SRS and Battery Light on W/High Voltage warning
  30. Air Control Valve
  31. Code explain help
  32. Seventh Generation
  33. brake pedal
  34. my tranny just died and I'm stuck at work
  35. deleted
  36. Where to find a motor mount or tranny mount?
  37. daytime running light problem
  38. No One Knows?? Problem Not Solved!
  39. battery or bad starter??
  40. whining noise while driving
  41. shifter rattle in 5th
  42. One Big Problem Very,Very Slow Civic(help)
  43. Buzz after downpipe install...
  44. 3 trannys later same sH*&!!!
  45. Engine Stalling
  46. Clutch or tranny??? Need help fast, Im stuck at work!
  47. Leaky Strut? I just got a brand new one free @ 130000km!
  48. Clicking Noises 7k miles!
  49. driver side rear door lock malfunction...
  50. weird sh!t gas cap won't open stretched cable
  51. 02 ex will not run right....pissing me off
  52. Cat
  53. Funny Plastic Smell from Undercarriage.
  54. Clunking noise, possibly transmission? Help!
  55. Tranmission Problem 03 Civic
  56. 2002 Honda Civic SI Axle Breakage
  57. Transmission
  58. Gas Guage n Some Squeeking
  59. alternator died already!? help!
  60. whats wrong with this??
  61. Dont know how to explain the problem, please read the post...
  62. Help! Engine Dies While Driving!
  63. Brake oil
  64. need pics of hinges of the trunk
  65. driver's door doesnt lock, but actuator seems to be making noise!
  66. Tranny gone? Auto
  67. Typical Noise............?!?!?
  68. Tranny??
  69. Car won't start help...
  70. Hazard Lights
  71. Tranny is gonna blow
  72. headers..
  73. intake rubbing on hood
  74. hood rattle
  75. Trunk Lock
  76. crazy squeaking in the back of my civic...
  77. trunk and gas opener resisting
  78. o2-speedo problem...help...
  79. Rain water in cabin
  80. My AC compressor doesnt turn on
  81. broken engine mount
  82. deafening intemittent humming
  83. Any advise anybody, check light on lumpy idle
  84. Funky Sounds
  85. Power Locks that don't work...
  86. Steering problem
  87. any other 7thgen out there with these problems????? arggghhhhh
  88. Innacurate Fuel Gauge
  89. SRS Light
  90. Cruise Control is not working.
  91. Tire wearing issue?
  92. Transmission Trouble!
  93. Metallic Chain Sound
  94. nothing works when key is out?????
  95. Squeeking Sound? Help!
  96. weird noises
  97. disconnecting srs
  98. Field day for the Dealer!!
  99. blinking check engine ligh
  100. lights dying.. grrr
  101. how much is a new automatic tranny? ****...
  102. my alternator dying?
  103. D17 transmission needed!!!!
  104. starting trouble?
  105. Car Leaking Air From Front
  106. Powerful brakes
  107. Idle at 1500
  108. ticking sound from left side
  109. R134A Refrigerant....
  110. whats the part# for this?
  111. shaky steering at 70mph
  112. I have a lot of problems
  113. Hondacare and TSB's
  114. lx headers
  115. engine is loud
  116. Women drivers should be considered a road hazard...
  117. Anyone know how to fix that annoying rattling sound from the rear????
  118. Help With My friends AC problem?
  119. Over-Reved (Check Engine Light On Now)
  120. Car not under warrenty, TSB Still apply ?
  121. weird noise
  122. fixed vtec myself
  123. Service manual on CD
  124. idle control valve issues
  125. some rattle when I press on the brake while stopped
  126. starter relay
  127. ABS light
  128. Rear Brake Light Question
  129. I was at Wendys today and...
  130. Top speed?
  131. Ringing Noise
  132. Shot Power Steering
  133. headlight went out
  134. Insurance Company problems. Need help
  135. oem headlights
  136. Bubbling Power Steering Fluid
  137. gauges
  138. 18" wheels??? Please Help???
  139. fog bulbs are smoking help
  140. 05 problems??
  141. need motor #3?
  142. lost a wheel lock/lug nut
  143. my car making metal scraping grinding noises!! help
  144. high pitched sqeaking noise while driving
  145. Loud bang on 1st and 2nd gear redline
  146. Loud bang after 1st or 2nd gear redline
  147. what honda says vs. what you guys say
  148. my left back seat wont unlock wtf
  149. removing the rear deck
  150. removing the rear deck
  151. 2001 Civic LX with EX parts?
  152. 2001 Civic LX with EX parts?
  153. !!help peeps.. fuse keeps blowin
  154. ops, delete this one
  155. Speedometer not Registering.
  156. Leaking Strut and Torn CV Boot
  157. Alternator
  158. Tranny problem...
  159. RPM drop during idle
  160. srs
  161. i need alittle help
  162. bad shake when i start
  163. Radio/security
  164. wtf is up with my auto tranny? HELP!
  165. wierd sound
  166. Stiker Plate
  167. license plate frame light
  168. Loose Steering Wheel
  169. Should I do my timing belt?
  170. RPM signal wire?
  171. seat belt alarm on 05 accord
  172. Different Clutch and Tranny Problem
  173. TSB's Technical Service Bulletins
  174. Abnormal Tire wear??
  175. warranty issue
  176. wats wrong with my car?
  177. my car was side swiped
  178. CEL Came on. Rocker Arm?
  179. Daytime Running Lights...
  180. Intake/Fuel Rail Plumbing Question
  181. sounds when turning left and seal peeling
  182. Ignition problems?
  183. Car kinda struggles in 2nd
  184. Lambo doors.
  185. Rev Limiter Kicks in at 3900rpm
  186. downpipe hits sway bar!! (help)
  187. Thunking Sound
  188. SRS light won't turn off. Did I break a wire?
  189. Car Hesitating bad.. Please help.....
  190. Shift Lever..........
  191. Compliance bushing????
  192. Headlight Help ...... Please????
  193. Headlight Help ...... Please????
  194. Maint. Req'd light reset and information
  195. projector headlights problem
  196. Speaker/3rd brake light rattles
  197. engine noise in '05 Civic LX
  198. wtf piece of shit 10a fuse - speedometer dead
  199. New exhaust hangs to low
  200. Lost radio code
  201. Steering Wheel Does Not Lock
  202. Hit a Pothole :(
  203. question about gauges
  204. Strange sound when Turn to left
  205. Drivers seat crooked
  206. Question for anyone who knows about wrecked vehicles getting fixed
  207. shift knob shakes
  208. Carfax Here!
  209. Check Engine Light
  210. The stupidest problem ever.
  211. stupid honda
  212. steering wheel shakes over bumps,etc.
  213. damn suvs
  214. Wierd Noises...
  215. Strut replaced under extended warranty...
  216. Everything rattles in my '05 interior after 3000 miles.
  217. rear springs sag
  218. O2 sensor wire harness
  219. loud catback system (help)
  220. Transmission problem - RPM flaring
  221. How many miles are on your clutch???
  222. Clutch Problem.. ?
  223. Heater problem
  224. EX Civic Front Bumper Flange
  225. 2nd gear poppin out
  226. break problems!! help
  227. Strange noise, I've never heard on a car!!!
  228. WTF?!?! My windows jus stopped...windowing..
  229. Help out with stupid hazard lights
  230. do i need a new clutch???
  231. Exhaust: Heavy vibration
  232. Need A/C Pollen Filter
  233. Wtf
  234. 70mph and the shocks break!
  235. Clicking sound when parking.
  236. Shaking Brake Pedal
  237. valve lifter noise/vibration
  238. Got a new transmission!
  239. Sunroof question
  240. My car makes me sad
  241. Hydrolocking?
  242. engine coolant leaking
  243. Arhrggg I think I just Busted a Coil Spring on my 05
  244. Solid motor mount question...
  245. Noise in front end
  246. i have a problem
  247. problem can't figure out . . .
  248. 04 EX Civic Engine Noise
  249. Engine Light On Code P0113 Help!!!
  250. AC problem
