New exhaust hangs to low
I just got my new exhaust on my car today.I got a DC header,Megan high flow cat and the evo2. when I got it all on it hangs really low where the two pices of the cat back hook together. It only 2 inches or so off the ground.Anybody have this prob or know how to fix it? Any help would be great!!!!
Thanks Josh
Thanks Josh
Thanks Josh
Thanks Josh
just cut the hangers and weld them up a little higher. make sure that you take good measurements
I dunno if this will help, but it might be worth a try...
Loosen all the bolts/nuts that hold the exhaust together. Push all of the exhaust upward, retighten all the bolts/nuts. I think Sport Compact Car did something like that on one of their project cars. If I remember right, the rear muffler hung a bit low, so they did the loosen and tighten idea. They actually got it too high, and had to adjust again.
I tried loosening everything and then adjusting it but when I tighten it back up it all goes the wrong way.it doesn't even sit under the heat shield. It's about 4 inches to the passenger side and it hangs literally only 2 inches off the ground.With the springs sagging in the rear to I can't even drive the car.
alxz310
Jul 30, 2015 12:18 PM
JUNITO
Jul 9, 2015 08:36 PM
fvckbg
Jul 7, 2015 07:08 PM
Causemo
Jul 5, 2015 06:42 AM
