Car Hesitating bad.. Please help.....
Old Feb 19, 2005
mndthegap1's Avatar
okay so i have dcsports intake, hp hearder, and cat back exhaust.
The car is hesitating really bad... when ever i step on the gas the car hesitates then after a few seconds, it kicks in and is fine.
if im allready on the gas and give it more its fine..
it only hesitates when the foot is off the gas and the initial step on the gas..
does anyone know what this could be from or what to check..
i could really use the help.
Old Feb 19, 2005
Alex1's Avatar
did u or did u not have a missing link on ur car when u were boosting?
u think it might have something to do with the spark plugs since u have colder plugs?
Old Feb 20, 2005
flotsamm's Avatar
Maybe you got a clogged injector..
Old Feb 20, 2005
y.0. KiLLa's Avatar
Powered by Honda
i think thats normal lag..whenever i let off the gas and step on it. the car doesnt respond then a second later it kicks in..
also, when im alrready on the gas it just kicks in..my car is mostly stock and it has done this since i 1st got it..so i dunt think u should worry.
Old Feb 20, 2005
Alex1's Avatar
maybe u miss the torque the turbo used to give u lol
Old Feb 21, 2005
mndthegap1's Avatar
alex yeah man i miss it allready car was so much better with the turbo
2 questions stupid yes but still... i didnt install the turbo, so where do i check to see if the missing link is still there ?
and second
how do i check to see if one of the injectors is bogged down ?
Old Feb 21, 2005
dariusld's Avatar
dariusld is an unknown quantity at this point
Replace your spark plugs. That is my guess.
Old Feb 21, 2005
Alex1's Avatar
and second
trade spark plugs with tom or with me, ill even come by, that way u have the OEM plugs not colder ones meant for forced induction.
on the right side of ur throttle body, u will see a little square looking thing with a blue and white sticker on it. it says denso sensor map, on the left side of the square thing it has a philips head screw. if that square thing has something aluminum or metal visible under it without taking it off, it should be about 1 inch i think, then ur missing link is still on. unless u never bought a missing link valve. if u have the missing link, lemme know ill uninstall it and buy it off u since i need it to make more than 8lbs of boost.
the injector i wouldnt know how to check that, i have no experience with it yet.
yeah im sure u miss the turbo, remember how u used to only give it just a lil gas on the highway and it spools and starts accelerating with ease? lol
Old Feb 21, 2005
tighten the throttle cable. There's a diy in vehicle probs forum.
Old Mar 4, 2005
dwi's Avatar
dwi
dwi is an unknown quantity at this point
talk to me man....i've been sending you PM's and nothing. i'm about to spend the money i saved 4 u. let me know!
Old Mar 5, 2005
EŽik's Avatar
Thats what I was thinking.
cable might have loosened up from the work done in the engine bay.
Old Mar 7, 2005
dwi's Avatar
dwi
ChristinaVHH
May 10, 2015 03:51 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
CivicVoz
Apr 16, 2015 08:07 PM
dooner24
Apr 14, 2015 07:51 PM
JjAnGPeETuL
Nov 8, 2001 06:37 AM
