Noise in front end
Old Feb 1, 2005
SatinSilver03's Avatar
SatinSilver03 is an unknown quantity at this point
Noise in front end
First off we're dealing with and 03 coupe. When ever I make a sharp right turn like when turning into a parking lot or something I hear this rattling noise coming from the front passenger wheel area. My friends car is also doing it. Anyone else have this problem or know what might be causing it???
Jonathan
Old Feb 1, 2005
Well, I found the problem, and how to fix it incase anyone else is having this problem.
http://www.hondalac.com/service/Bulletins/x03-009e%20revised.pdf#search='2003%20honda%20civic%20 service%20bulletin'
Old Feb 1, 2005
streetglower's Avatar
that has nothing to do with what you described. You said you heard a rattling noise from the front suspension when you made sharp right turns. The Honda thing said a clicking noise made in 2nd gear on right hand turns. I think your problem is different.
Anyways refering to that chart, honda only sets a flate rate of 4 hours for that job. Doesnt seem very long. I think it would take longer. But you always get screwed over on warranty work.
Old Feb 1, 2005
Well it is more of a ticking sound. Im almost 100% sure that this is what the problem is. And 2nd gear makes sense because i notice it when i am slowing down making a right turn into a parking lot or at an intersection.
Old Feb 2, 2005
Da1lyDr1ver's Avatar
well, if its not your second gear thats making the sound, then its most likely your CV joint. when it goes bad, it tends to make a knocking sound when you turn.
edspyhill09
Jun 12, 2016 02:45 PM
Lopes101
Jun 7, 2015 08:04 PM
chuffsy
May 15, 2015 12:50 PM
pheaton
May 4, 2015 08:26 PM
GH04si
Apr 15, 2015 08:13 PM
