8th Gen 2006 - 2011.
2010 lxs 25600 miles , drive shaft/cv joints
Old May 14, 2015
chuffsy's Avatar
chuffsy is an unknown quantity at this point
Hello everyone. This might not be new news regarding the cv joints but I am just sharing my recent repair. It's a 2010 LXs with 25600 miles and recently while making hairpin turns I heard the typical clack clack clack sound from the front end. I was made aware of this possible issue by a honda tech friend of mine , but at the time , over a year ago they were fine. Well the warranty ends at 5 years or 60k , maybe its 50k miles not sure. I took it to the dealers and they were changed at no cost under warranty. So If you have a 2010 or 2011 , do yourself a favor and make a few hard turns to the left and right ( full lock) and see if your drive shaft assembly is defective. I would not have realized this unless I was turning hard . Hope this helps and oh by the way , the new ones are now warranted also!
Old May 14, 2015
Poopies's Avatar
Super Moderator
Re: 2010 lxs 25600 miles , drive shaft/cv joints
Thanks for the heads up! I hope it's just an isolated issue, but I'm glad Honda covered it!
Old May 15, 2015
chuffsy's Avatar
Hi Poopies,
Aparently most of us dont realize they are defective till a full lock is done. Hopefully the issue can be caught early enough before they really get worse and the warranty runs out ( Warranty info is in a separate booklet , that comes with the car) . I happened to drop by my tech friend one day and was telling him that the car is doing great , as to be expected with low miles for its age. Then he asked if my cv joints were ok as civics have been coming in with low as 15k miles for drive shaft replacements. I would think the new ones installed are a diferent batch than the originals. Nevertheless the car is doing great . The drive shaft is the first repair to be done and as a preventative measure I also changed the air conditioning magnetic clutch relay ( located in the fuse box , engine bay) with
the supposedly improved one ($18 , Dealer) , as the originals have been known to fail prematurely.
Old May 15, 2015
CraigW's Avatar
Did the boots rip at any point ??
Did you or previous owner beat on it ??
Old May 15, 2015
Nah, it's like there was a batch of lousy ones or maybe they didn't get enough lube inside, that made it to the assembly line.
Xuhme
21
Aug 7, 2023 03:40 PM
Bruce.Ringler
Jun 18, 2015 08:12 AM
sccarally
Texas
May 17, 2015 10:11 PM
bsmiley
Apr 27, 2015 01:27 PM
smmahan
Apr 15, 2015 08:17 PM
