8th Gen 2006 - 2011.
2011 LX sedan wiper problems
Old May 14, 2015
pratik05's Avatar
pratik05 is an unknown quantity at this point
About two months back, I had both my wipers changed to the Bosch evolution (24 & 26) ones and they seemed to clean really well. But about a month after installing them, the passenger side wiper came off on its own while I was driving in a rainy day, and the whole blade flew off to the road. I picked it up and found that the clip got broken somehow, which is why it came off. The Autozone guys were happy to replace it with a new one.
However, this happened again yesterday on the new passenger side wiper and it came off. Same story- the clip got shattered to 5-6 pieces. This time I noticed however that the blade was bent outward out a bit just under the spot where the arm hooks itself to the wiper.
At first I thought it was that particular piece, but now I think it could be my wiper arm. The driver's side wiper is still fine and they make no funny noise when in operation. Did anyone face a similar problem ever? Or am I missing something very obvious that might be causing this? Any help/hints/insights would be much appreciated.
Old May 14, 2015
jordan1794's Avatar
jordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nice
Re: 2011 LX sedan wiper problems
Did you install them first, or did the Auto-zone guys do it?
Remember that they do it all the time, and it's probably pretty obnoxious..
Watched them replace my wife's wipers on her old car (2001 mercury grand marquis)
I swear the guy was within 1/2 inch of snapping the thing in two...they are not gentle with it.
I'd pop the other blade off, is you are comfortable you can get it back on, and compare the two arms and see if they look the same. Could definitely have something bent that is causing the issue.
Old May 14, 2015
pratik05's Avatar
I installed both of them myself following all the right directions. The driver's side wiper functions ok, so I don't think installation is the issue here.
But I will try taking them both off and compare the arms as you said. Thanks for the tip
Old May 14, 2015
brags's Avatar
"Honda - tried, true & tested...!"
brags is an unknown quantity at this point
those are high quality blades.. i have the same blades I installed myself a year ago with 0 issues. turn on the wipers and check your wiper arm that the blade attaches too.. on the passenger side. for any abnormal movement
Old May 14, 2015
pratik05's Avatar
Hmm I did check both the wipers for any abmormal movement, and so did the guy at Auto-zone. Guess I now need to see another same model wiper arm to compare whether mine is bent or not. I am thinking the Honda dealership might be able to inspect any problems
Old May 15, 2015
CraigW's Avatar
Never cared for the fits all plastic adaptors, they do fail too often.
Did you keep your stock blades ??
Old May 15, 2015
pratik05's Avatar
Yeah I still have my stock ones.
Old May 15, 2015
CraigW's Avatar
^^^ Factory has worked great on my 2010.
Love the no need for winter blades any longer.
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
autowill
May 15, 2015 11:36 AM
shindrome
Exterior
May 5, 2015 02:50 PM
carid
Apr 30, 2015 07:00 AM
C6GrandSport
Apr 25, 2015 09:41 PM
