AC problem
Old Jan 31, 2005
kfk256's Avatar
kfk256 is an unknown quantity at this point
Question AC problem
My air conditioner on my 2001 coupe (48k mile) quit working, the green light comes on when i push the AC button, but it would not cool and i don't hear the compressor come on and off like it used too. All the fuses seem to be okay, except for the fact that i couldn't locate a specific fuse for the AC in the panel under the steering wheel. Naturally i'm thinking my compressor has a problem and i got one for cheap on ebay ($30). Can any one show me how to replace the compressor with pictures and tips. thanks in advance
Old Jan 31, 2005
koolaidman's Avatar
koolaidman is an unknown quantity at this point
hahahha
dont do it unless u have the 1000 machine to recover the r-134a
btw did u even diagnose the problem...maybe its not the compressor
maybe its the connector to the magnetic coil???
maybe u have low refer
look into it before u change into a parts changer
Old Jan 31, 2005
streetglower's Avatar
like koolaidman said, you need to diagnose it. Does it blow air, or does it not blow air? You need to hook up a set of manifold gauges to the high and low side and see what the static pressure is with the AC off, then see what the pressures are when the AC is running on high, and at 1500-2000 rpm.
You could have several problems. Bad compressor, bad field coil, bad clutch, maybe getting now power to the feild coil, low refrigerant which means you have a leak somewhere, bad thermostatic switch, could be anything.
Old Jan 31, 2005
kfk256's Avatar
It blows air just fine but not cool air.
Old Jan 31, 2005
koolaidman's Avatar
ya but u still need to hook up some gauges to know whats really going on
go buy a 100 set of guages hook them up tell me high press and then low pressure should be arround 75 psi on both ends if not its low
run the system max cool and recirculate tell me whats the high side and then the low side
dont remember numbers off hand but when u do ill tell u if its good or not
with out doing this....U WILL NOT FIND THE PROBLEM!!!!!!!!!!
Old Feb 1, 2005
EX4Dr's Avatar
EX4Dr is an unknown quantity at this point
While the car is idling, have someone turn on the AC while you watch the compressor and its pulley.
- If you can hear a click and see the pulley speed change then the problem is probably the compressor. Have it service professionally.
- If there is no click sound and the pulley speed does not change the problem probably is a fualty magnetic clutch, or its wiring, or its relay.
To check the AC clutch: Turn AC on and off and listen for clicking sound coming from the compressor pulley.
To check the relay: Locate the relay. Turn the AC On and Off and listen to see if the relay turns on and off (clicking sound).
To check the wiring: Locate the AC compressor and visually inspect the cable coming off of it for sign of damage.
Old Feb 1, 2005
koolaidman's Avatar
listenin for the clicking sound is only half correct
use known good relay to check...if plug it in and cold air comes out its the relay...
Old Feb 2, 2005
75 PSi on the low side is too high. It would be ok with the car off for static pressure, where both are within 10 PSi or so, but when the A/C is running, that is too high. Should be between 25-50 PSI.
Diznavis
Jan 25, 2002 11:25 AM
TeamStylesRacing
Jan 20, 2002 08:38 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
