Left axle leaking
Old Jun 14, 2005
nindoo's Avatar
Why is my vagina bleeding?
Left axle leaking
I'm bringing my car in this week because my left axle is leaking.
22,058.67 miles on my car.
2k2 ex coupe. stock front sway bar is 25.4mm. What could cause this premature wear and tear: hard cornering, or bumps and potholes in the road. My car doesn't pull left or right, and my transmission isn't slipping.
Old Jun 14, 2005
tacheon's Avatar
tacheon is on a distinguished road
Accelerating into turns is the only reason I can think of which will cause a lot of wear on your CV joints.
Old Jun 14, 2005
dariusld's Avatar
dariusld is an unknown quantity at this point
I'm sorry, but what is a "leaking axle"?
Old Jun 14, 2005
nindoo's Avatar
I guess the boot is cut or broken.
Old Jun 14, 2005
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Could have caught some crap on the road and cut the boot.
Old Jun 14, 2005
nindoo's Avatar
I figured it was my luck, but at the same time I do take so on off ramps a little to delightly.
Old Jun 16, 2005
CuRiOuSfIsH's Avatar
Back From The Banned!
how about accelerating hard when the steering wheel is full lock?
Old Jun 16, 2005
nindoo's Avatar
never did that.
Who knows how bad it is they replacing left axle seal
Old Jun 16, 2005
wonderz's Avatar
wonderz is on a distinguished road
never did that.
replacing the seal isn't that hard.
taking the axle out would probably take you the longest.
you have just to buy a new boot from kragen or something, then replace your old one. they'll also come with new grease and it can become messy when you try to apply it.
Old Jun 16, 2005
dariusld's Avatar
Is it leaking oil out of the transmission or is grease coming out of the cv joint boot? You keep talking about two different things, I'm confused
Old Jun 17, 2005
nindoo's Avatar
Honda said they are repalcing the left Axle seal. So I figure its the axle that is leaking, but I didn't check the car myself.
Old Jun 17, 2005
dariusld's Avatar
So there is nothing wrong with the actual axle?
Old Jun 17, 2005
nindoo's Avatar
is the left axle seal a very minor replacement?
Old Jun 17, 2005
wonderz's Avatar
yes, but if you let Honda do it, they gonna charge you a handsome amount for labor.
Old Jun 17, 2005
dariusld's Avatar
Getting to the seal is the hard part. You have to remove the axle to replace the seal. Easy for me or Honda, just takes a little time. For you
People could help you better, if you were a little clearer with your question from the start.
Old Jun 18, 2005
nindoo's Avatar
They replaced the LEFT 1/2 SHAFT seal.It shows to pieces used on the invoice. The work was done under warranty.
Old Jun 26, 2005
robbclark1's Avatar
Retired suspension supermod.
My just started leaking. Sealed it with Black RTV for now. You just need to replace the boot, but you got it done under warrenty.
Old Jun 27, 2005
dariusld's Avatar
He said his SEAL not his boot, read the whole thread.
Old Jun 28, 2005
nindoo's Avatar
Thanks for the input guys.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
Poopies
Apr 20, 2017 11:36 PM
sk8ermommie
Jun 9, 2015 10:41 PM
Jigee
May 9, 2015 11:18 AM
CapYoda
Jan 7, 2002 03:20 PM
