Help With My friends AC problem?
Well I am asking on what everyones opinions are on this problem my best friend is having with her 1998 Ford mustang's AC system.
Here is her complaint, and I verified it., kinda.
Anyway, she was complaining that sometimes her AC was blowing cold air and sometimes it would blow warm air. Now when i turned it on, it was blowing semi cold air, but I was possible thinking she might have a condensor fan problem on that. But I didnt see the condensor fan, just a radiator fan. But I didnt look long enough. I was also getting line temps and couldnt remember if the line going to the accumulator, and the line coming off of it going to the compressor were supposed to be the same temps. The line from the evaporator going to it was warm, and the line coming out of it to the compressor was cold when the clutch engaged.
Now the main thing with this is when she turns on her AC to max cold, as soon as the compressor clutch engages, the cars idle starts to jump around and the car sounds like it wants to die. But when the clutch disengages, everything is fine untill it engages again. My feeling is she might have a compressor problem. like the reed valves are failing.
what do you all think?
I think you're right. Have you tried driving the car for 20mins+ at constant freeway speed to see what happens with the AC on? She just may have forgotten to use it during the winter and the lubricant seized up or something.
But I still think it is a compressor problem.
I don't think there is anything wrong with the compressor. It sounds like the a/c is working as it should. However, check to see if the idle air control valve (or idle speed motor) is faulty. What is supposed to happen is the idle air control valve is supposed to step up the idle when the a/c compressor is engaged due to the increased engine load. If this does not happen, you will get a rough idle. You will need to hook up a diagnostic tool to it to see if it is doing this. You can try to test it by doing this. Turn on the a/c such that it idles rough as you described before. Step down on the gas gently to increase the idle speed. See if that smooths out the idle. If so, I'd be suspicious of the idle air control valve.
Also can I test the idle air control by turning on the heat full blast and with all accessories on and see if it does the same thing?
Turning on all accessories doesn't produce a huge load like an a/c compressor engaging. It should increase the idle speed but you wouldn't notice an idle problem if the idle air control wasn't working. Turning the heat on full does nothing since all that does is open up a valve on the heater core. Compressors usually have a bearing, clutch, or shaft seal failure. When any of those die it is very obvious. A bearing failure will cause compressor noise/squeal or totally seize the pulley. A clutch failure would result in no compressor engagement. A seal failure will also result in no comperssor engagement due to the fact the refrigerant leaking out and it triggers the low pressure cutoff to protect the compressor.
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
pincookie1
May 4, 2015 12:22 PM
tylerginevan
Apr 27, 2015 12:29 PM
