Engine Light On Code P0113 Help!!!
Hi guys, my check Engine Light goes on after i installed my cold air intake, so I took it to Ammco Tranmission for a Code Scanning, the code is P0113 which it say Intake Air Temperature (IAT) Sensor Circuit High Voltage. I tried to unpluged the battery and leave it for 15 mins, and i even tried to install sock intake but the light still on. Has anybody had that problem before? and how to solve it? thank you so much
did you plug the IAT sensor back in when you installed the intake?
If you did, I can give you the steps from the manual to check it. Most likely it will come down to needing to replace the sensor. But let me know if you even installed it
well most likely you need a new one. But I can tell you how to diagnose it to see what the problem is if you want. You will need a voltmeter for it though.
Also did you plug the connecter into the sensor? Hate to ask, but I have too.
ok disconnect the IAT sensor 2P connecter. Connect the IAT sensor 2P connecter terminals number 1 and number 2 with a jumper wire. This is the wire side of the connecter. Then turn the ignition on. Dont start the car, just turn the ignition on. Now check if 5V is indicated. If not, then you need to replace the IAT sensor.
Otherwise, if there is 5V indicated, then you need to connect a jumper wire between PCM connecter terminal A10 and B17. And with the ignition on, see if there is 5V. If there is, either update your PCM, or see if the problem goes away with a known good PCM. If it does, replace the PCM.
If there isnt 5V indicated, then you have an open between the PCM (A10, B17) and the IAT sensor.
For this you will need either a HDS scan tool or a snap on or other scan tool.
Originally Posted by koolaidman
u got that off all data didnt ya witch 1 is the p2 connector? and on the pcm witch 1 is connector A and witch 1 is connector a and b on the pcm and witch terminal does it start from left to right or what...could help if he had color....and u dont need a scan tool just back probe the iat sensor or pcm
I did Connect the IAT sensor 2P connecter terminals number 1 and number 2 with a jumper wire. This is the wire side of the connecter. Then turn the ignition on. check if 5V is indicated. However I didn't get any Volt. So what do you thing the problem is?? do u thing because of any fulse or wire or something?? the engine light still bothering me so much guys, thanks.
If you didnt have any volts, then you need a new IAT sensor.
I used 2 jumper wires to connect the IAT sensor with the 2P connecter then I use the Volt metter to check if i have 5 V or not. First of all i checked its Ohm to make sure that i connected them right and I show me it has some Ohm ( it meant i connect them right). however when i checkec its Volt, i didn't get any Volt. oh yea, I wonder that where is the 5 volt come from? what is the power source for that 5 volt??
But on the first one you did, did you use a volt meter, and if so, what did you hook it up to to check for voltage? What exact points?
Flipg123
May 8, 2015 01:15 PM
tylerginevan
Apr 27, 2015 12:29 PM
dooner24
Apr 14, 2015 07:51 PM
bahena08
Apr 11, 2015 05:09 PM
