steering wheel shakes over bumps,etc.
Old Feb 12, 2005
1955's Avatar
hi, my 2001 coupe right front tire glazed over a curb few months ago with only slight damage to the rim,that was 2 months ago,not sure its the cause or not, now the steering wheel will shake only the tires are going over bumps and pot holes (small ones), does fine on smooth road, thanks for any input.
Old Feb 13, 2005
EX4Dr's Avatar
EX4Dr is an unknown quantity at this point
The steering knuckle and the balljoint may have been damaged from your previous impact. Jack up the car with the damaged wheel off the ground. Hold the wheel at the 3 and 9 o'clock position and twist forward and backward to see if there is any play in the suspension. It sould be tight. If there is play then you need to replace balljoint and/or steering knuckle.
Old Feb 13, 2005
1955's Avatar
ok,thanks, the steering knuckle is a heavy piece of steel but the balljoint at the bottom which connected to the A frame may be damage? ok, i already check the balljoint at the end of the tire rod and its tight but the grease fitting rubber cap had been torn for some months,i looked everywhere except the dealer for the upper ball joint without any luck, i will check again thoroughly again tomm.thanks.
ok, i could not get a accurate feel of any wobble from the wheel bcz the steering wheel can not locked in place as older cars,however, i didnt hear any unusual noise when i shaked the wheel,oh well,i will greased up the upper ball joint with a grease gun this time,i used my finger to apply some this morning but i dont think the grease could reach the ball though.patient is the key cus my wallet is not fat.thanks
conspiracy90
Jun 7, 2023 01:01 PM
bravo79
Suspension
18
Feb 10, 2022 09:52 PM
Fudman
Suspension
Feb 1, 2020 04:13 PM
honda200192
Suspension
Oct 27, 2019 12:23 PM
RickyRocket
Nov 30, 2001 10:14 AM
