My AC compressor doesnt turn on
2k1civic.com O. G.
AFter a whole winter of not using my AC it doesnt seem to work anymore.
The AC button lights up but i dont hear see or feel the compressor engaging like it used to.
This is what i mean when i say:
Hear - Engine RPMS raise up slightly when at idle and AC is turned on.
See - Lights dimming slighting from extra electrical load
Feel - Feel the engine from the RPMS raising.
I checked all the plugs going to it and they are fine. (engine bay)
What gives? my car is an 2001 and my AC has worked flawslessly till now. Is it possible that maybe the refrigerant leaked out and now the compressors safety thingy wont let it engage? Im sure it cant just break by itself.
Could be the low pressure safety switch. It will prevent the compressor from running if the refrigerant's too low or gone. If you know where the switch is, you can jump it and see if the compressor starts. DO THIS ONLY FOR A FEW SECONDS! The compressor WILL seize without R134. If it works, you have lost the charge and need to get the system checked.
Originally Posted by AzNmiKex215
does R134 last forever? as in, the only way you can "run out" is becuase of a leak?
But yes a leak is the only way to lose it.
dinsum
May 28, 2015 09:30 PM
jc33312
May 12, 2015 03:17 PM
crowtoo
May 11, 2015 06:50 PM
alexkharden
Apr 23, 2015 07:13 PM
