Transmission problem - RPM flaring
Old Feb 8, 2005
climacus's Avatar
climacus is an unknown quantity at this point
Does anyone know if the current generation Civic slushbox still uses a throttle pressure cable to modulate the shift harshness? My auto transmission is slipping the clutch between 3rd and 4th and the RPM is flaring under light acceleration. The last time it happened, Honda gave me a new transmission. Now 20000 miles later, the problem is returning. I want to get this addressed before I burn up another clutchpack. Thanks!
Old Feb 8, 2005
streetglower's Avatar
it shouldnt matter if you are under warranty.
Old Feb 9, 2005
flotsamm's Avatar
I think he's trying to determine if there is a cable, since it can be adjusted to make the shifts firmer and stop slipping. On trannies that have a pressure cable, you can adjust the line pressure.
Wild Cranker
May 19, 2015 06:10 PM
cruisers10
May 12, 2015 10:46 PM
Richkid23
Apr 19, 2015 12:53 PM
McD
Apr 16, 2015 10:46 AM
dooner24
Apr 14, 2015 07:51 PM
