engine is loud
Old Mar 13, 2005
bngu1's Avatar
bngu1 is an unknown quantity at this point
engine is loud
i bought an 05 ex coupe auto about 4 months ago and the engine seems to be louder and louder everyday. it has about 5k miles on it and running mobil 1 0w-20 oil. when i press on the gas the engine is loud and hums. is that how our car is or is it just mine?
Old Mar 13, 2005
y.0. KiLLa's Avatar
Powered by Honda
its V-TeC Son!
Old Mar 13, 2005
bngu1's Avatar
i'm sorry for asking this stupid question, but vtec is suppose to be louder?
Old Mar 13, 2005
D5cIvIc's Avatar
Old Mar 13, 2005
y.0. KiLLa's Avatar
Powered by Honda
ok if it is in park or nuetral and u rev ur engine it gets louder and u can somewhat hear a huming noise..same thing for mine...i dunt think ne thing is rong with ur whip, u might just be siking urself out..muhaha if u think there is a problem just bring it back to the dealer since it is under warranty.
Old Mar 13, 2005
bngu1's Avatar
it's just as you described "y.0. Killa". i just wanted to make sure, cause it seems a little bit loud for a new car. thanks
Old Mar 13, 2005
y.0. KiLLa's Avatar
Powered by Honda
awesome..but just to double chek when u bring ur car in for maintenance just as k them about it.
Old Mar 14, 2005
Stachmo's Avatar
"You leave me in the trenches taking Grenades, John"
Stachmo is an unknown quantity at this point
yeah, what vtec does is it opens up the valves in the engine slightly so you gain a little bit more power. Next time you go out start off in first gear and floor it...you'll notice the tachometer slowly gaining rpm's then once it gets to a certain point (I think its like 5000rpms or something), it should start moving much faster up the chart and you should feel a little more pull in the engine. Thats the vtec kicking in and it does make the engine sound a little louder (that and the fact that your revving your engine up high will also cause it to get louder...lol)
Old Mar 18, 2005
12sec elcamino's Avatar
12sec elcamino is an unknown quantity at this point
Maybe if you took out the water you have for engine oil and put in some thicker oil like the oil cap says it may quiet it down some! I have put 10w30 mobil1 in my car since the forst oil change and my engine is just as quiet as the day I bought it except for the ac compressor, I now have 42k on it. I live in Florida so a thicker oil is just fine for my climate, now if you live in Maine or Alaska then I can understand the 0w-20
Old Mar 26, 2005
Mistro's Avatar
Mistro is an unknown quantity at this point
Thought that all honda's had that whining sound? I have a A1 and between 2.5k and 3.5k it whines a bit. Definatly not vtec because its an A1.
Or is there something wrong with my alternator im not knowing about...
Old Mar 26, 2005
It's normal. Our engines are loud, but you won't hear vtec unless you got some engine work done. It's just air flow you would hear on the newer vtec.But I'm using stock 5w20 oil and have a few mods. It's not that loud unles you put an intake on or something.
edspyhill09
Jun 12, 2016 02:45 PM
marciano117
Jun 25, 2015 09:06 PM
WhosYoDadday85
Dec 30, 2001 06:31 PM
supercivic01
South
Nov 30, 2001 11:27 AM
TrevH01
Bolt-on Engine Performance
Nov 11, 2001 03:25 PM
