Powerful brakes
Old Mar 21, 2005
return_2020's Avatar
return_2020 is an unknown quantity at this point
Powerful brakes
I know that honda has less powerful brakes than others,(Nissan). Is it possible to upgrade the caliper, which has two pistons ? will this make the breaks more powerful than current. Or what is the other way of doing this ? please advise.
Old Mar 21, 2005
Zzyzx's Avatar
Autocross Junky
Honda's have allways had a soft pedal feel.. but that doesn't mean the brakes are weak. it just means they feel different from other companys.
Old Mar 22, 2005
teamPR0's Avatar
Won By One
teamPR0 is an unknown quantity at this point
you can try out some rear disc brakes. get a whole conversion.
Old Mar 22, 2005
EX4Dr's Avatar
EX4Dr is an unknown quantity at this point
Honda seems to have weak brakes because they use skinny tires to get better fuel economy. Upgrade your wheels/tires and you'll see dramatically better braking performance.
Old Mar 25, 2005
K20CivicTypeS's Avatar
K20CivicTypeS is an unknown quantity at this point
The quickest and cheapest way of upgrading your brakes would be new pads, like EBC greenstuff, and new fluid with a higher boiling point than stock. I prefer ATE Super Blue. Makes a noticable difference and costs way less than rear disc conversion or bigger wheels/tires.
Old Mar 25, 2005
wonderz's Avatar
wonderz is on a distinguished road
rear disc doesn't really help improve braking distant much since most braking power comes from the front...
also tires are what stops you on the road, if your tires doesn't grip, then even the biggest brake in the world can't help you. think of it as like driving on ice... even if all your wheel stop spinning but your tires can't grip, your car still moves...
Old Mar 25, 2005
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
I can't believe you're suggesting EBC greenstuff to him. Try hawk or Axxis.
Old Mar 28, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
EBC destroys rotors. Hawk all the way.
Old Apr 3, 2005
tfnaaf's Avatar
BLDNPSI Mod
proper rear brake adjustment and a performance front brake pad of your choice will improve pedal feel and braking performance. But when you get your brakes to work that much better then your tires come into question if they can hold traction and not skid. Your cars will only stop as fast as your tires will allow.
Old Apr 6, 2005
Metallica454's Avatar
The Beer-man
Metallica454 is an unknown quantity at this point
I thought we had single piston calipers...
Old Apr 14, 2005
cubanmike26's Avatar
Inertia is a very powerful force. I was thinking about upgrading to Power Slot Rotor w/ Hawk Pads. Are they a good set up? How big of a diference in terms of braking power will one feel after?
RIPSAW
Nov 6, 2015 04:36 AM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
MamaBear2015
Jun 11, 2015 07:33 PM
Killagi
May 14, 2015 10:08 PM
bsmiley
Apr 27, 2015 01:27 PM
