Need A/C Pollen Filter
Old Feb 6, 2005
greggdogg's Avatar
greggdogg is an unknown quantity at this point
Any idea where I can buy one/how hard it is to change?
Old Feb 6, 2005
streetglower's Avatar
you can buy them at the dealer, autozone, or off the web.
Just remove the glovebox, and behine it there will be a little piece that you have to remove then the 2 filters are right behind there. Really simple to change.
Old Feb 6, 2005
Does anyone know where I can get some of the rsx filers that also have odor guard? They're supposed to fit our cars as well.
Old Feb 6, 2005
greggdogg's Avatar
Ooh, that'd be nice. What should they cost?
Old Feb 6, 2005
not cheap I will tell you that. Probably at the Acura dealership.
Old Feb 6, 2005
greggdogg's Avatar
What about the stock ones for the Civic?
Edit: Found it, dirt cheap:
http://www.handa-accessories.com/civmaint01.html
Old Feb 6, 2005
Off the internet, the lowest I found was $9 a filter at www.handaaccessories.com
Old Feb 6, 2005
Those you can just vacuum out. I've never actually replaced mine and I'm at 30k miles. They still look fine but get dirty very fast. I say vacuum in each crease every 5-10k miles. But the civic ones do not filter odor.
Old Feb 6, 2005
If you have odor in your ac you need to see if your drain tube off your evaporator is clogged. Those collect mildew and can cause odor. Also you can spray some disenfectint in the evvap case.
Old Feb 6, 2005
No I'm talking about outside odor filtration. Like when something smells nasty outside (exhaust or whatever) it comes through the filters. The acura ones block odor from getting in when the circulation is set to outside air. I used to have that mildew smell when I constantly would keep my car in recirculate mode. I now just keep it to fresh air and the smell is gone.
Old Feb 6, 2005
12sec elcamino's Avatar
12sec elcamino is an unknown quantity at this point
Napa had mine in stock, they were the regular ones though, they work well for me, when I fart I put the window down so the odor filteratation ones are not a big deal to me. They were about 25 bucks for both, came in one box. Hope this helps.
OptimisticWay
46
Oct 15, 2015 02:16 PM
andyandyy
Aug 4, 2015 06:37 PM
jpandjf
Aug 3, 2015 05:02 PM
jessica19699
Jul 30, 2015 01:02 PM
Jul 14, 2015 03:39 PM
