Car not under warrenty, TSB Still apply ?
My car is under warrenty and I'm having TPS Sensor problems,
I know there is a TSB issued somewhere for this but I'm unable to find it at the moment, I'm also wonder if honda would still do it for free since my car isn't under warrenty ?
If it is out of warranty, then you will have to pay for it. TSB's are notices that a part will be replaced under warranty. A recall on the otherhand will be replaced free of charge no matter if you are in warranty or not. If you are having TPS problems, then most likely you need a new throttle body. The part is about $270 and $70 labor from honda to install it.
Originally Posted by AlienX
your fvuck kidding me.
I can't just change the sensor :'(
screw labour.. I DIY Everything..
What makes you think the sensor has failed?
oh and you can get the throttle body off www.hondaautomotiveparts.com for like $140.
hey alienx...umm just wondering since your in canada...do these tsb forms work in canada?...cause i have 2 problems listed...slow retract seatbelt, and slow pass window. And the form says copyright american honda...
for the seatbelt, the tsb just says to clean the top holder that the belt moves through. It says dirt buildup causes it to go slow. Same with the window prolly, although I haven't seen a tsb for that one.
i called honda and well, they told me that the TSB is not valid when the warrenty expires. You should just give them a call, it should be active for Canada also or just drop by your dealership.
Did you ask if Honda would fix something for free under warranty????? Hahahahahahahahahahahahahahahahahahahahahaha!!!!!! !!!!!!!!!!!!! They have a hard enough time fixing things for free when the car is under warranty!
blacklud
Apr 13, 2015 06:15 PM
gabrown2
Apr 11, 2015 08:22 PM
JjAnGPeETuL
Nov 8, 2001 06:37 AM
Ill give that a shot
