Transmission Trouble!
Old Mar 31, 2005
StreetKnight's Avatar
StreetKnight is an unknown quantity at this point
Unhappy Transmission Trouble!
I have a standard transmission and recently after a trip to the dragstrip my car won't go into reverse or lock in fifth gear. I've had a couple of mechanics tell me it's my syncs and a transmission shop said it will cost 2 grand to replace the syncronizers. But they also said to get some standard transmission additive and it should relube the syncs to activate agian hopefully. All I need to know is how much transmission fluid the transmission takes so i can put about 25% of however much fluid is in there. Give me some feedback please.
Old Mar 31, 2005
hotrodcivic2004's Avatar
my civic has no boost
2 grand? seems steep. u can get a brand new transmission for 1000. what year is it? still under warranty?
also, the 5 spd. holds 3.2 pints according to my chilton manual.
Old Mar 31, 2005
Jeromie's Avatar
Jeromie is an unknown quantity at this point
manual tranny is only a grand? i have a automatic and its goin out, i was gonna get a level ten tranny rebuild kit. my car shifts up and down out of nowhere. then one time first gear wasnt grabbin. anybody know wtf is goin on. i dont really feel like its slippin cuz when in wot it works perfect. it also happens more on cold starts and low aceleration.
Old Mar 31, 2005
wow dude that sux. yeah, or a used manual i've seen ~500. i wanan swap out my auto for a manual. but i'm also thinking of just getting a 6th gen si and decking that out. um yeah get that auto fixed man, unless yur out of warranty. my auto was dying on me and got fixed under warranty, thank god cuz i just hit 36,000 miles last week.
yur solenoids are most likely teh cause, they are fvcked up. yeah when u floor it it doesnt 'feel' like its doin it, but it is. i bet yur redlining in yur auto rnt u, i mean like...7,100 rpm then i'tll switch. a healthy auto should be shiftin ~6,500 WOT. but yeah i'd get that fixed before yur car doesnt move. lol
Old Mar 31, 2005
pnoyster2k1cvic's Avatar
Balut Eating Champ
when you step on the clutch does it have any pressure to it? does it vibrate when you hold it halfway? I just busted my clutch too and gettin ready to put another brand spankin new set of Stage 2 ACT on it!!! the other one only lasted me about a year... I don't even race that much... I can't wait to dyno my ride and find out how much torque my lil D17's putting out
EDIT: if you drive an auto i'll just >>> myself
Old Apr 1, 2005
o $hit i forgot u had m/t
Old Apr 1, 2005
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
I said this a million times, but no one listens....
But here it goes one more time. Put a tube of Moly grease in the gearbox. NO, it won't hurt anything. YES, the Moly helps protect the synchros and gears, and bearings.
Yes, My own sh*t tranny shifts like greased snot now. I have used Moly in all my hondas and my Nissan tuck. Shifts great after over 150,000 miles. I recomend using Moly ESPECIALLY if you drive hard. It won't prevent you from breaking the gearbox, but it will help keep it alive a lot longer.
NO... honda engineers did NOT know what they were doing when they designed the 7th gen transmission.
If you have to replace the tranny, put a tube of Moly in the new one. It takes a couple hundred miles for it to really plate into the metal, but you'll see.... it will run smoother.
Aww, well... good luck.
Old Apr 2, 2005
Mike4831's Avatar
Mike4831 is an unknown quantity at this point
I had the gears in my transmission replaced because of a recall. I had similar problems. Have a dealership check it out.
Old Apr 3, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
DO NOT! fix your transmission for 2 grand. Just buy a used one with like 10k miles for 500$ and get it installed rather than fixing your old one.
SidCivic
44
Oct 12, 2017 03:39 PM
dust
Sep 20, 2016 06:39 PM
knknif
Aug 4, 2015 06:11 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
