RPM drop during idle
Old Feb 28, 2005
mooncake2's Avatar
mooncake2 is an unknown quantity at this point
Folks
I have a 2004 Civic 1.7 which is showing intermittent drop in rpm during idle (700rpm -> 400rpm). Sometimes, the car can shudder pretty badly when dropped to ~400rpm. The rpm will get stucked at ~400rpm and refuse to rise again. The engine, however, never stalled.
I noticed 2 things though:
1. This never happens at night. It's always day time when the drop happens
2. The worst cases happens when the car is low in fuel (ie around the time when the low fuel indicator is up)
Any thots on this, anyone?
Someone told me that it could be the fuel relay. Is this possible? What's a fuel relay anyway?
Old Mar 1, 2005
streetglower's Avatar
check your idle air control.
Old Mar 1, 2005
ajhdragon's Avatar
7thgens official a$$hole
^^^^yup thats what i was thinking.
Old Mar 1, 2005
mooncake2's Avatar
how to check?
Ii'm pretty new to this. Can you pls explain how do I go about checking the idle air control?
Old Mar 1, 2005
Bires's Avatar
Bires is an unknown quantity at this point
Some tips:
1. Take it to Honda for an adjustment. It's under warranty.
2. NEVER let your gas tank get below 1/4 tank. The more volatile (hotter, less even burning) hydrocarbons are lower in density and rise to the top of your gas tank, even with the mixing that occurs when you are driving. Studies have shown that the last 10% of your gas can have an octane rating as low as 80.
Old Mar 18, 2005
eddiechaps's Avatar
i love my morreale
my car idles weird but it's more like when i start it. It'll idle at like 1500RPM. Once i start going it'll idle at about 1000. Then, after a while it drops back to the usual 700RPM idle. I just noticed this yesterday. Would it be the same issue with mooncake2's engine with the idle air control?
Old Mar 21, 2005
2K1Civic17"Gabe's Avatar
mine stays at 1500 for about 3 or 4 minutes, than drops down. If i tap the gas, it will stay right back up there. Can we alter the pressure or something for idle, how to we control the idle vacuum
Old Mar 22, 2005
That almost sounds like your throttle cable is too tight. You need 0.5 inches of play when you push down on the cable before it starts pushing it open.
Old Mar 22, 2005
1PHATSI's Avatar
proudpinoy
1PHATSI is an unknown quantity at this point
it does too in my vic. in the morning when i
start the car rpms about 2000 thenafter a while it drops down,
its because the engine is cold. then 5 mins. drops to normal
Old Mar 22, 2005
flotsamm's Avatar
Thats normal. Its suppose to rev higher when cold so that the engine gets warmer quicker. Then it gradually drops until the engine reaches operating temp.
Cajunkev1
Apr 3, 2017 04:32 PM
mistermenphis22
Jul 13, 2015 04:43 PM
Khmi
Jun 23, 2015 11:03 PM
Wild Cranker
May 19, 2015 06:10 PM
slam2k1civic
Jan 22, 2002 03:10 PM
