2002 EX auto. RPM drop, stall, limp home mode. Video included
Old Jun 23, 2015
Khmi's Avatar
Khmi is an unknown quantity at this point
Hello all, the past couple of weeks my 2002 Civic EX has been having problems, the problem only occur in the evenings, after its been parked outdoors in 70+ degrees temperature days, when I driving home.
The car starts up fine, once the engine temp get to normal, the RPM will suddenly start to drop, fast and only for a sec, the CEL will pop up during that time, but goes away. It can occur during acceleration, cruise, or deceleration. At stop lights the car will sometimes will nearly stall, or completely stall. The car has gone into "limp home mode" 3 times, slow acceleration, tach and temp gauge stops working, with CEL on. But if i pull over and restart the car it works perfectly normal.
If I shut the car off and scan it when I get home, it shows no code. Once with it was in "limp home mode" and I drove the car home and scanned it the scanner says it cannot connect to ECU (using snap-on blue point scanner). I've tried changing the alternator, thinking that there is a voltage spike causing it to go in to limp mode. But that didn't work.
Lucky when driving home one day I caught the RPM drop and limp mode on camera. The car doesn't stall when it goes into limp mode. You can hear the pitch change in the engine. Any help would be nice. I don't want to spend a fortune trying change things that aren't broke.
Video Link:
Old Jun 23, 2015
Re: 2002 EX auto. RPM drop, stall, limp home mode. Video included
Some guesses:
Make sure the top mounting bolt for the alternator is actually tight, along with the rest of them.
Make sure the ground cable connections from the battery to the transmission and body are clean and tight
Make sure the 2 groups of ground wires on the thermostat housing are clean and tight
Old Jun 23, 2015
Khmi's Avatar
Originally Posted by ezone
Some guesses:
Done, Done, and just cleaned on the grounds. thanks for the input
CarStuff
Dec 6, 2020 12:52 PM
Civic2002lx
Oct 7, 2015 09:17 AM
civic__duty
24
Jun 11, 2015 12:29 PM
izdman
May 19, 2015 03:43 PM
oqjoi
Transmission
May 6, 2015 06:27 PM
