Help! Engine Dies While Driving!
Old Apr 19, 2005
1stcivic's Avatar
1stcivic is an unknown quantity at this point
Exclamation Help! Engine Dies While Driving!
so i'm driving down the road the other day and my battery light came on. i did what it said to do in the owners manual (basically turn everything off except the engine). i take my car to an auto parts store and have them test the battery and the alternator. they said that the battery was about to crap out but the alternator was cool. so i buy a new battery and swap it out right there in the parking lot. now 4 days later my car has trouble starting and when i do get it started my ABS, SRS, MAINT REQ'D, BATTERY, and CHECK ENGINE LIGHT come on. then my car dies!
PLEASE HELP!
Old Apr 19, 2005
streetglower's Avatar
sounds like the alternator if you ask me. I would take it back and have them look over it again. Usually when the battery light comes on that means there is a problem in the charging system, and the alternator is where I would look.
Old Apr 19, 2005
1stcivic's Avatar
just one problem... car won't start at all now.
Old Apr 19, 2005
probably cause your battery is dead. your alternator charges the battery, if it fails, the battery voltage will drop untill the battery is dead. go check the voltage at the battery?
Old Apr 19, 2005
1stcivic's Avatar
a brand new battery will go completely dead that soon?
looks like a certain auto parts store just screwed me out of some $$$$
thanx
Old Apr 19, 2005
1stcivic's Avatar
update:
after letting my car set for like, 5 or 6 hrs, it started but just barely. as soon as i tried to roll up my window all the same indicator lights came on.
Old Apr 19, 2005
thanx
If you put a new battery in the car, and go to start it, but the alternator is bad, your battery has no way to get charged, and it will go dead like that.
Old Apr 19, 2005
Civic04's Avatar
Civic04 is an unknown quantity at this point
Got to be a dead alt. When you put the windows up its takeing all the power away thats why the engine is dieing. Go to a diff store and have them check it (if one is close enough that you can fully charge the battey with a charger and get there)
Or call a garage
Old Apr 21, 2005
paradoxblue's Avatar
yeah alt gone.
the battery no matter how good/new it is will run the car by itself for only a short time. then pfft.
thats a new term for the car dieing.. "pfft"
Old Apr 21, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
thats why i was always scared with the aem pulleys which replace the alternator pulley and powersteering/
Old Apr 22, 2005
xxhonda4lifexx's Avatar
xxhonda4lifexx has a little shameless behaviour in the past
go to autozone, they will charge your battery for free; then, take your car to a local repair shop.
Old Apr 22, 2005
pnoyster2k1cvic's Avatar
Balut Eating Champ
I have UR Pulley Set and no problems so far... except for my tranny
Old Apr 22, 2005
2K1Civic17"Gabe's Avatar
Go back to the same place, and have them replace the battery for free. There should be a warranty on it. Most everywhere has a warranty on them. But get an alt. as well
Xuhme
21
Aug 7, 2023 03:40 PM
mrcell24
May 19, 2015 10:02 AM
McD
Apr 16, 2015 10:46 AM
smmahan
Apr 15, 2015 08:17 PM
crazydragon
Nov 7, 2001 05:13 PM
