fixed vtec myself
Old Mar 11, 2005
02CIVYEX's Avatar
02CIVYEX has a little shameless behaviour in the past
Talking fixed vtec myself
well there was a thread that i posted up about 2 months ago about my vtec not working and the dealership not wanting to fix it, well i decided to fix my self so what i did was take the valve cover off and i took a look at it and there was bolt loose layin in front of vtec oil jernal(excuse my spelling) not lettng any oil go to the locking pins for vtec so i put the screw where it belonged and reassembled it and took it for test drive and the vtec was working check engine light stayed off let me go past 4k rpm all that time vtec wasn't working just cause of that bolt. i glad it did not touch the cam or valves
Old Mar 11, 2005
_Viper_'s Avatar
congrats man ...good 4 u
Old Mar 11, 2005
rEkKaShInObI's Avatar
Unsalvageable
honda dealers are pretty mest up these days....
Old Mar 11, 2005
Caucasian.Asian's Avatar
glad you were able to fix it. too bad you didn't know it was just a loose bolt in the first place.
Old Mar 11, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
uh wtf? ... how did a bolt get in there in the 1st place ?
Old Mar 11, 2005
thrash_273's Avatar
deploy,engage,destroy.. to fail is not an option
thrash_273 is an unknown quantity at this point
good catch!
Old Mar 11, 2005
dirtySAMURAI's Avatar
I log in from time to time
are you sure you know what you're talking about?
Old Mar 11, 2005
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Errrr..... if a bolt came loose in the head, I'd suggest you put red locktite on it if you didn't already. It may work itself loose again.
Old Mar 11, 2005
accat13's Avatar
accat13 is an unknown quantity at this point
when replacing my valve cover gasket on a suzuki swift if found one bolt laying beside a valve spring,and 2 other very loose bolts....I would suggest cleaning the bolt with alcohol as well as the nut or bolt hole.Then use the red locktite like tinman suggested.High temp, high vibration loose bolts = major problems ..ps hope you checked for more loose bolts...
Old Mar 12, 2005
02CIVYEX's Avatar
well i guess the machine shop didn't tighted it or something cuase it was just laying there by solenoid.
dbagaus
SOHC D17Ax non-VTEC - VTEC Engine Swaps
70
Feb 22, 2023 04:26 PM
lilrob1213
37
Jun 29, 2015 06:45 PM
Vaguexo
Jun 13, 2015 04:13 AM
tadr88
Jun 8, 2015 12:28 AM
01civyv3
Jun 2, 2015 05:21 AM
