2nd gear poppin out
Old Feb 7, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
2nd gear poppin out
when I made a long turn on second gear it usually pops out. A new clutch would probably fix that, but 2nd gear also grinds 50% of the time. A new clutch assembly wouldnt fix that right?
Im going to an exedy clutch and act flywheel set soon, so I want to know if it will fix it. If it wont fix it, I want to have a transmission ready so I can use a new tranny.
I dont want to buy a new clutch and flywheel set for my messed up tranny if it aint going to fix the 2nd gear grinding. Im pretty sure the synchros are messed from hard shifting. Only 2nd gear as of yet with 70k miles. Would I be able to put in a new clutch and flywheel for the tranny right now then down the road when I get a new tranny would I be able to take the clutch and flywheel out to put it in the new tranny?
Old Feb 7, 2005
streetglower's Avatar
if second gear is popping out or slipping out, your linkage might be misadjusted, or you have worn synchros. Now if it is grinding in second gear only, then you need to check your second gears. they probably have busted teeth on them.
Old Feb 7, 2005
im stock now! T.T
will a new clutch stop the slippin out of gear?
I can take grinding but not popping out of gear especially while racing. It grinds maybe 50% of the time.
Old Feb 7, 2005
flotsamm's Avatar
Maybe this is it.. I took this out of TSB: sb626650 Shifts Stiff or Pops Out of Gear.pdf
SYMPTOM
The shift lever feels hard to move from gear to gear, or the manual transmission pops out of 2nd or 5th gear, usually during deceleration.
PROBABLE CAUSE
The shift cable end is corroded at the transmission, which causes a stiff feeling when shifting (this may also cause the transmission to pop out of gear). The clearance between the interlock and transmission case wall is too large, and 2nd or 5th gear tooth contact length is too short, causing the transmission to pop out of gear.
CORRECTIVE ACTION
Replace the cable bushings if corroded, or replace the transmission case housing, 1-2 shift fork, 2nd gear set, 1st gear, and 5th gear.
WARRANTY CLAIM INFORMATION
In warranty: The normal warranty applies.
Operation Number: Repair Procedure A: 213003 Repair Procedure B: 213107 Repair Procedure A & B: 213108
Flat Rate Time: Repair Procedure A: 0.5 hour Repair Procedure B: 5.8 hours Repair Procedure A & B: 6.3 hours
Failed Part: P/N 21210-PLW-BO0 H/C 6568158
Defect Code: 037
Contention Code: B99
Skill Level: Repair Technician
Out of warranty: Any repair performed after w,arranty expiration may be eligible for goodwill consideration by the District Service Manager or your Zone Office. You must request consideration, and get a decision, before starting work.
REQUIRED MATERIALS
Honda MTF: P/N 08798-9016, H/C 4928271 Urea Grease: P/N 08798-9002, H/C 3720984
Tyler93
Mar 20, 2016 09:03 PM
Whitexj
Sep 30, 2015 02:04 AM
meicalnissyen
Sep 22, 2015 06:20 PM
BBrosario
Sep 17, 2015 07:51 PM
rayaan_wasty
Sep 14, 2015 02:00 PM
