Jerky shifts?
Jerky shifts?
Hey guys, I just recently bought a 93 hatchback automatic transmission. The engine and trans only has 87k original miles on it. I know these things aren't the smoothest shifting cars, but driving around I've noticed it jerks into gear some. When it downshifts it jerks also. The jerks are usually shifting in 1st and 2nd and comin to a complete stop. Sometimes the jerks are more noticeable than others, and it's not like a snap your head to the steering wheel jerk, but it is a noticeable little kick. I actually bought it from a dealer he said they never touched the transmission fluid, but the fluid is at the correct level and looks almost like new. I've read it could be a tps, or throttle cable? The cable didn't seem very loose at all when I looked but then again I've never really messed with tthem so not 100percent sure what it should be. Any help or advice on the issue would be greatly appreciated.
Re: Jerky shifts?
Re: Jerky shifts?
Hondas DW1 fluid may get it to shift a little less firm than Dexron.
I always thought those older transmissions shifted rather firm to begin with, and I personally prefer that they do.
If the fluid is clean and there aren't any other issues, I might say to leave it well enough alone as it may be normal. Can you find another old Civic to compare with?
Newer cars really shift soft compared to some of those older cars. It's just how they were made.
Re: Jerky shifts?
Re: Jerky shifts?
Just bought myself an 88 DX yesterday. Kinda the same problem. When I go from park to drive or reverse it shifts hard into gear. Once engaged it shifts fine, I get the thump into gear just when I put it in drive. Normal?
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
ricer_em2
May 11, 2016 08:09 PM
sesi
Oct 1, 2015 02:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
