EX coupe FOB Factory??
Old Sep 18, 2015
meicalnissyen's Avatar
meicalnissyen has a spectacular aura aboutmeicalnissyen has a spectacular aura about
Just got this car, its a 2001 civic EX coupe
found an "extra" wire while doing a quick pre purchase inspection, otherwise all stock. I now think the wire is to a alarm system.
I've searched a good bit on youtube, but do not see the remote fob that I was given with the car.
I have 2 keys, one ILCO for the ignition, and a strattec for the doors
the fob in the photo takes 2, CR2016's
Question:
Is this an OEM FOB ??
will I be able get a 2nd ignition key made at a non dealer key shop??
Thanks
Sorry if I missed the answer in a prior post
Old Sep 18, 2015
Re: EX coupe FOB Factory??
Fob is not from Honda.
An EX would have been equipped at the factory with keyless entry.
As for keys, you would need a correct key and it needs to be programmed to the car (immobilizer) if the blank can't be "cloned". Inquire with your key seller before attempting.
Old Sep 18, 2015
Thank you Sir
Old Sep 18, 2015
Factory fob would have been this style (may or may not have the trunk button)
Old Sep 18, 2015
The factory fob I received when I first got my 02 looked much like this one
It broke a long while ago and replaced it with the one that ezone posted up
Old Sep 19, 2015
OptimisticWay's Avatar
OptimisticWay is an unknown quantity at this point
That is the one my 05' EX SE came with. I didn't have the trunk release 😓. Stupid key.
Old Sep 22, 2015
Thanks for the replys guys!
as a follow up
My locksmith noted that the door, and ignition keys have different cuts.
Is this standard for Honda?
Or has one of the locks been rekeyed??
THANKS
@ezone;
Old Sep 22, 2015
As far as I know, door and ignition should use the same key
Old Sep 22, 2015
You already knew this, yes?
NO.
No, more like whichever lock is the oddball got replaced.
(I would like to believe that) anyone with enough brain cells and lock tumblers to rekey a lock would make them all use the same key.
Old Sep 22, 2015
Oh yeah, I knew, I just had no reason to have an opinion until locksmith asked if that was normal
Both are aftermarket keys, but the ign has more wear
I put batteries in the fob (omega 4415)
and it does nothing. dunno if its lost its programming, or if it just was for the alarm I noticed underhood
NO.
eh, yes, but as an example, My speed needed its PCM replaced, it came with a ign set which I swapped in (still needed dealer reflash) so I now have different door /ign (though they also sent the door tumbler, PIA to replace so, for now, 2 keys.
Now I have to search for a how to on the FOB prog, that at least was easy on the speed, hoping the honda as well
THANKS
Old Sep 22, 2015
key off to on 4 times with a fob lock press each time
Easy
Old Sep 22, 2015
If you are trying to program that non-factory fob, you need to find the alarm (or remote start) control unit and google that manufacturer, see if you can get some instructions for it.
If you have obtained a correct Honda fob, that's a piece of cake to program yourself....assuming nobody screwed with it when they installed aftermarket stuff.
Kevin_646
Jun 24, 2015 11:00 PM
h4ldol
Jun 3, 2015 03:26 PM
