Car Not Wanting To Run
Old Jun 20, 2005
Turbociv's Avatar
Turbociv has a little shameless behaviour in the past
My civic key immoblizer light is on.
The tachometer and engine temperature gauge does not work.
It will not Rev over (About) 3,000 RPM
It is running extremely rich
It is an automatic and is running on 2 gears. 2nd and 3rd
It takes forever to get up to speed 1/4 mile= 40 MPH SLow as Crap
Does anyone know what could be wrong????
Old Jun 20, 2005
Michalo187's Avatar
Abortion Survivor
are you running rsx injectors? Are you tuned?
Old Jun 20, 2005
Turbociv's Avatar
Well the thing was my car was running perfect and then all of a sudden it did all this at once. I am tuned and i am not running enough boost to need to upgrade to new injectors.
Old Jun 20, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
electrical conflicts in the ecu. go to mechanic. now.
Old Jun 20, 2005
Michalo187's Avatar
Abortion Survivor
^^^^^ Yeah i agree
Old Jun 20, 2005
Turbociv's Avatar
well i retraced all the wiring and all was fine.
Could it be the ECU?
Old Jun 20, 2005
Michalo187's Avatar
Abortion Survivor
Maybe it can be you should just have it checked out by a professional
Old Jun 20, 2005
Turbociv's Avatar
I took it to Honda 2 times and 3 other garages
Honda said they didn't know what was wrong cause their computer couldn't read my ecu
the other garages said they thought my ecu was burnt out
I took it apart but i didn't see any blown circuit or resistors or anything like that.
Old Jun 20, 2005
Michalo187's Avatar
Abortion Survivor
Dam honda wtf well what about the guys who tuned you they should know You didnt switch keys did you??
Old Jun 20, 2005
MajinB's Avatar
is it under warranty? swith keys? that car would not start. anyway your ecu is fried or partially fired if the car runs. tow it to your mechanic and make him fix your crap. then call a lawyer. good luck
Old Jun 20, 2005
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
The civics ECU has a secondary or redundant microprocessor inside it. In case of primary processor failure, this secondary "brain" will attempt to run the car in an albeit crippled condition, but it won't leave you stranded. This is designed so you can get to a shop or Home. Try having the ecu swapped. It is likely damaged if all the wiring is in order. And you DID do a total reset???
Old Jun 21, 2005
Turbociv's Avatar
I did do a total reset of the computer and it still didn't fix it.
It is out of warrenty and i tried both keys that honda gave me. They both acted the same.
I ordered an ECU it should be here thursday or friday so i will get back then about the problem and see if that fixed it.
Anyone know where i can get cheap injectors for my car though?
Old Jul 9, 2005
mx-5killer's Avatar
mx-5killer is an unknown quantity at this point
Your not alone
Hey man i had the same problem,i bougth a ecu for my car and im taking it to honda so the can program the key of the car to the computer and hope that resolve everything.i have a 2001 dx automatic
Old Jul 15, 2005
Island2K2's Avatar
Island2K2 is an unknown quantity at this point
im having the same problem... new computer?? or what i need my car asap!!! anything will help before i spend $$ on things i dont need
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
mikemc422
Aug 9, 2018 05:41 PM
usajags84
15
Aug 19, 2015 03:12 AM
Geoff_Geoff
16
Apr 30, 2015 12:17 AM
aZnVoYCe
Bolt-on Engine Performance
Nov 4, 2001 10:18 AM
