high speed shakes on cold engine
when i start my car and don't warm it up much, it'll shake at speeds over 60 and get worse. the front steelie is slightly flat in one spot. i searched and think it's likely a alignment issue, but after about 3-4 miles of driving with this bad shake, it goes away just like that. still sound like alignment?
i think the pressure is ok. all wheels should be within 28-30 psi. and yes, only when i start the car and drive within a minute. if i do some city driving before highway, the problem doesn't happen.
Well, if it stops when the car warms up... the simplest solution is just to let it warm up for a minute! If it's really cold and your car sits outside, try pouring some gas line anti-freeze in. It helps.
ok now i am 85% sure it is the tire sealent i put in there just getting cold and stuck at the bottom of the tire
i guess tire sealent doesn't take to tires too well in cold weather, next time i'll know...
i guess tire sealent doesn't take to tires too well in cold weather, next time i'll know... Thread
anddrrey
May 11, 2015 02:30 PM
Ninetyatecivic
May 9, 2015 07:48 PM
pincookie1
May 4, 2015 12:22 PM
Hobby2K
Bolt-on Engine Performance
Nov 9, 2001 04:08 PM
