Transmission is FUBAR
Ricerus Maximus
Rep Power: 308 Transmission is FUBAR
Originally posted by OsOBooSTeD
ok... now uve gotten problems.... i had the same thing happen to me and honda DID fix it.... Apparently what happened is the throw out bearing went bad... which gave you your first symptoms... NOW since you have the rattling noise... which happened to me only when the clutch wasnt pushed in , is the input shaft.... whats happening is that the throwout bearing is done, and because that happened and you neglected to fix it , you have destroy'd the other bearings, the pilot , etc... and NOW the input shaft is vibrating against the whole tranny.. causing more problems and soon tranny failure. NOW because youve waited so long to get it fixed ... its not just a throw out bearing problem.. there are many parts that u may or maynot have destroyd or ruined. You really need to get it fixed before you tranny falls out your car ... literally.
My other question is has anyone done a tranny swap with a used tranny and had any problems with one of them?
OsOBaNNeD
Rep Power: 0 new trannyy 300 bucks www.car-part.com
Rep Power: 0 before u buy the tranny, buy one for an 03 b/c the ones from the early 02's and all 01's are messed up from the factory matter how many times u rebuild them.
Rep Power: 0 Disgruntled 01 Owner
You guys are really starting to scare me...
I put my 01 EX in the shop to have a couple things in the MT checked out (sometimes won't go into 1st and very rough going into 2nd). When I got it back, not only was the problem with 1st still there, but there were MORE It was making a slight whining noise (almost like a P/S pump) with the clutch pedal out, but not with it in.
Now, my car has always idled very quietly, so this came as quite a shock... especially since they had it for a week.
So I gave it back to them... and they call me up today to tell me that the cause of the noise is a bearing. I don't know which one, but it sux nonetheless.
With specificcivic's comment about 01-02 MT's being junk and my warranty expiring in a few months, I can already tell I'll be spending many-a-weekends in the auto hobby shop putting in an 03 drivetrain.
WTF
WTF
Ricerus Maximus
Rep Power: 308 the problem is the input shaft bearing. that's exactly the noise mine was making at first, and now it's a nice rattleing.
check your warranty information. There might be something about a 100,000 mile powertrain warranty, just have to check. If nothing else stay tuned in, I'm about to contact Honda Corporate about this.
jackoncruzpr
09-29-2015 07:59 PM
Elciteeve
09-28-2015 12:40 PM
jerry38
09-20-2015 08:38 AM
