Need Help Taking Off Air Filter Panel
are you trying JUST to replace the filter?
if so, you just need to remove the screws around the cover (like 5-6) and 1 in the center.
and yank it out!
and yank it out!
Is one of your screws stripped?? One of mine was and it wouldnt come loose. The dealer now had to order new top and bottom air filter housing units. Oh and you do need it, I think it is an 8mm socket, and than twists with a screwdriver.
DaveyD:
how much dealer charge you for new screws for air filter, cuz I twist too hard on center screw, almost stripped!!!........i needed new one for next time to cleaning air filter....... Pls let me know how much you paying for that.........
thanks
thanks
Quote
[hr]Originally posted by: MIT
DaveyD:
thanks[hr]
DaveyD:
thanks[hr]
Did you also try to use a socket? Cuz the ones on my airbox are hex screws, which would lead me to believe that there are 2 ways to tighten/loosen the fasteners.
vtecbrah
May 12, 2015 01:30 PM
Ninetyatecivic
May 9, 2015 07:48 PM
