Trunk won't stay shut!
Old Feb 11, 2003
badcivic2002's Avatar
badcivic2002 is an unknown quantity at this point
I installed some fat mat in my trunk, and I am working on a fiberglass sub encl. But, when I went to shut my trunk it closes. When I pulled up to see if it was staying shut and it popped open. No matter what I do it still will open back up. Anyone have any ideas?
Old Feb 11, 2003
Krepoort's Avatar
Krepoort is an unknown quantity at this point
Did you put any of that stuff in the trunk lid? If you did, you might be pushing against the wire for the trunk release. If you look at the left hinge of the trunk lid, you will see a wire clipped to the side and snaking into the trunk lid. Make sure that wire is not being restricted. Start there and see if it helps. Also pull on the trunk release by the front seat and see if the resistance has changed.
HTH
-Kre
Old Feb 13, 2003
MangoEX's Avatar
Just Be
MangoEX should not be trusted
Excellent response.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
Jeffdp
Aug 5, 2015 11:38 AM
brian257
Jun 4, 2015 08:17 PM
Supramk3
May 11, 2015 07:55 PM
