engine light on HELP SOON
Old Feb 23, 2003
jrock2324's Avatar
jrock2324 is an unknown quantity at this point
I was driving my car on the freeway when I notice some was wrong. Every time I step on the gas the car would shake. And the engine light came on. It don't stay on it blink. So I pulled over and pop the hood. I check everything out but noting was wrong. The only thing that I put on the car is a ingen CAI and some spark plugs. I did smell something when I pop the hood. But I could not tell what is was.[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Feb 23, 2003
slystad810's Avatar
Take it to the dealer and have them run the code. If the light stays on it means get yo @ss to the dealer!
Where in Detroit are you from? I'm in Warren.
Old Feb 23, 2003
nutrawk669's Avatar
nutrawk669 is an unknown quantity at this point
Quote
[hr]Originally posted by: jrock2324
I was driving my car on the freeway when I notice some was wrong. Every time I step on the gas the car would shake. And the engine light came on. It don't stay on it blink. So I pulled over and pop the hood. I check everything out but noting was wrong. The only thing that I put on the car is a ingen CAI and some spark plugs. I did smell something when I pop the hood. But I could not tell what is was.[IMG]i/expressions/face-icon-small-confused.gif[/IMG][hr]
Well, find out what the smell is. Is it metallic, does it smell like benzine(the stuff that you smell in gasoline), does it smell like oil or transmission fluid? What is the sound your engine is giving? There is a ton of feedback you can get from using your other senses; don't simply rely on your eyes. If you're not mechanically inclined, however, just take it to the shop.
Does your engine shake all the time? If so, perhaps one of the plugs isn't firing. I've had that happen in my '87 'Lude.
If your car's still under warranty, never fear. Simply pop your stock airbox and resonator back on, and take it in. Explain what's wrong.
Also, check in the manual about the engine light codes. From your description, it could be anything from fuel injector problems, to a bad spark plug, to a small feral child caught in the intake.
Old Feb 23, 2003
jrock2324's Avatar
Quote
[hr]Originally posted by: slystad810
Where in Detroit are you from? I'm in Warren.[hr]
I stay behind henry ford hosiptal
Old Feb 24, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Try resetting ECU / Check Ground wires on the Injen CAI.
Moving to Vehicle Issues/Problems...
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
jetcare101
May 8, 2015 01:33 PM
Flipg123
May 8, 2015 01:15 PM
tylerginevan
Apr 27, 2015 12:29 PM
