Generic front upper strut bar?
Old Jan 9, 2003
asianmatrix02's Avatar
asianmatrix02 is an unknown quantity at this point
I have a "type r" front upper strut bar from ebay. everytime i start up the car the engine hits the bar and makes a thud sound. it isn't causing any problems except the sound is bothering me. it only happens on startup. i was wondering if anyone else had this problem and how did you fix it. i bought some rubber feet from home depot but they keep on moving around after a couple of start ups.
Old Jan 12, 2003
Ronin's Avatar
Ronin is an unknown quantity at this point
Your strut bar should not be so close that you're actually touching the engine on startup. If that's the case then you probably shouldn't be using that particular brand of strut bar.
Old Jan 12, 2003
well the spacing is about 1/4" and it is a light tap through the contact of the air filter housing. it isn't causing any problems and i just put a rubber spacing between it so it doesn't make that sound anymore
Old Jan 29, 2003
david02civic's Avatar
I'm The Shit
david02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusted
I have a strut bar also, im not experiencing the thud sound but i noticed while installing it, it hit my brake fluid container> i had to do a little modifying to stop it from scraping it
Old Jan 29, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
dc/neuspeed baby!!!
Old Jan 29, 2003
dc/neuspeed baby!!!
yea i wish. i would have gotten neuspeed but under a college student's budget that isn't going to hapen
GH04si
Apr 15, 2015 08:13 PM
Daniel420
Dec 4, 2001 08:46 PM
0100010
Bolt-on Engine Performance
Nov 26, 2001 07:50 PM
PlatnumBomb
Nov 9, 2001 01:11 PM
andylao
Nov 4, 2001 01:19 PM
