Brake light flashes on and off
Old Oct 3, 2005
vicride345's Avatar
vicride345 is an unknown quantity at this point
Every once in awhile my brake light will flash on the dash board. Is this telling me something with my brakes are going bad? It only used to come on when I applied my e-brake but now it comes on at other times also. Please help if you can thanks
Cody
Old Oct 3, 2005
CraigW's Avatar
Have you looked at the brake fluid level ?? If you are between 40-60k miles you probably need front pads. Don't add fluid, when the pads are replaced the level will return.
Old Oct 3, 2005
04vic's Avatar
04vic is an unknown quantity at this point
need more brake fluid
Old Oct 3, 2005
streetglower's Avatar
make sure you also check for any leaks. When that light comes on, either you are low on fluid, or you have a leak somewhere. Or the sensor has a intermittent connection.
Old Oct 3, 2005
Pn0ybOiLiKehOy's Avatar
Pn0ybOiLiKehOy is on a distinguished road
or if you have a stiff ride a bump might cause the ebrake to bounce up and down
Old Oct 4, 2005
vicride345's Avatar
My arm is rest on the ebrake so I don't think its the e-brake. It is mostly when I press on the brake is when it comes on
Old Oct 4, 2005
check your brake fluid
Xuhme
21
Aug 7, 2023 03:40 PM
CarStuff
Dec 6, 2020 12:52 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
MamaBear2015
May 27, 2015 12:04 PM
civic_gt
Apr 19, 2015 08:15 AM
