****Back plate touching rotor = Stranging clicking noise when turning right
Old Aug 13, 2005
MIR's Avatar
MIR
~Your Favourite CiViC GiRL~
MIR is an unknown quantity at this point
So when i turn right to turn (not from stopping at a sign) or turn around a csharper corner i hear this nasty click click noise sounding like its coming from the right side of the car by the wheel etc... no idea whats wrong but just checking if anyone knows before i take it to honda mon or tuesday
thanks!
Old Aug 13, 2005
streetglower's Avatar
does it happen everytime you turn? If so, it sounds like a bad CV joint. But there could also be other things wrong.
Old Aug 13, 2005
Jrfish007's Avatar
Sounds like CV joint, maybe not, but it's common on Honda's with more than 75k, or really any FWD car with that kind of milage. I know on my old Accord it was around $200 to fix, prices may have gone up tad.
Old Aug 14, 2005
etdigitalis's Avatar
etdigitalis should not be trusted
i'm gonna have to agree with the others and say it's most likely your CV joint. a lot of times this happens due to the rubber boot that surrounds it (and holds in the grease) cracking and exposing the joint to the elements.
just to give you an idea of how much the repair would cost for a CV joint... list price from honda is $104... so when you factor in part mark-up and labor, expect to pay $2-300.
Old Aug 14, 2005
zen_master's Avatar
any quick idea how to fix it? seems like its not DIY-able eh?
Old Aug 14, 2005
yikes thats what happened to my old car. Didn't think that would break for a while on the civic tho.
Old Aug 14, 2005
i'd say it's a few steps above doing your front brakes... 'cause beyond the effort involved with that, you need to take off your spindle nut and pop out your lower ball joint to get access to the axle behind the hub.
so if your comfortable with that, than i'd say it's completely DIY-able.
Old Aug 14, 2005
MIR's Avatar
MIR
dbl post..
Old Aug 14, 2005
MIR's Avatar
MIR
the car has 82000k
i do have extended warranty though, wouldnt it be covered?
boo if i gotta pay 300 for this thing... ill kick their *****
Old Aug 14, 2005
Originally Posted by MIR
the car has 82000k
if you have extended warranty, they should cover it. However if the boot is damaged exposing the joint, they wont cover it.
Old Aug 14, 2005
Jrfish007's Avatar
Even then, you may be able to hagle it, saying they put a defective boot on it.... worth a try
Old Aug 14, 2005
Jrfish007's Avatar
Well defective might be the wrong word.... matbe saying you thought it was covered in the warranty or something.
Isn't that pretty much how all the CV joint go, don't think I've seen one go that had a good boot on it, suppose it can happen, just haven't seen it.
Old Aug 15, 2005
MIR's Avatar
MIR
UPDATE: Turns out it was the back plate of the part of the wheel/brakey thing rubbing against the rotor and they just had to bend it back cost $30! yay!
Old Aug 15, 2005
Shifty's Avatar
dang mir, u got ripped off
Old Aug 17, 2005
MIR's Avatar
MIR
why ripped off? lol..
Old Aug 17, 2005
K20me's Avatar
If it was just the brake dust shield, you could've bent it back yourself with a set of pliers FOR FREE!
Old Aug 17, 2005
zen_master's Avatar
well now at least he didn't have to breath the brake dust........
does it worth $30? lmao
Old Aug 17, 2005
MIR's Avatar
MIR
im a gurl # 1
#2 i took it to honda to get it diagnosed and then once it was done they said ok it was blah blah blah and its all fixed and nits $30..im like huh?:
otherwise i woulda fixed it myself
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
civicns
May 8, 2015 09:49 PM
edgenet
May 2, 2015 08:00 PM
Dorval Andre
May 1, 2015 09:37 AM
supercivic01
South
Nov 30, 2001 11:27 AM
