transmition clicking?
Old Sep 8, 2005
fixeruper's Avatar
fixeruper is an unknown quantity at this point
ok, i have had this clicking coming from the transmition. i first thought it was the throttle bearing, nope i was wrong although it did look a little worn. i also replaced the stock clutch with a act stage 2, but the clicking hasn't gone away, what should i do...
replace trans. OR
take off trans and have a shop repair it
thanx in advance
Old Sep 9, 2005
turboengnr's Avatar
DONT PANIC
i had my input shaft bearing come apart on me. But it didnt make a clicking noise.
Did you ever think that it may be your axels? When they go bad, they click like hell when going around turns.
Old Sep 9, 2005
fixeruper's Avatar
i dont think it would be my axles, for a couple reasons, it makes the clicking at an idle, and when driving straight, i heard from a good friend it might be imput shaft. but the only problem i need to have little as possible down time for its my daily driver
Old Sep 9, 2005
mradam85's Avatar
mradam85 should not be trustedmradam85 should not be trustedmradam85 should not be trusted
^i have the same problem, someone please help tia
Old Sep 10, 2005
turboengnr's Avatar
DONT PANIC
does the noise go away after you push in the clutch? If so, then its your input shaft bearing.
I just diagnosed one today. My new transmission has a bad input shaft bearing. (Thanks Derek!! )
Old Sep 10, 2005
fixeruper's Avatar
lovely, thanks
Old Sep 10, 2005
bgoetz's Avatar
bgoetz is an unknown quantity at this point
what other problems can you have from driving with a bad imput shaft bearing? because mine does the same thing and stops when I push in the clutch I always just thought it was annoying, but would cause no real problems is this true.
Old Sep 10, 2005
fixeruper's Avatar
another thing is there someone making an upgrade version of the imput shaft so it wont come back nearly as easy
Old Sep 10, 2005
hk2ronin's Avatar
hk2ronin is an unknown quantity at this point
I have that same noise, honda voided my warranty due to aftermarket parts so now Im in touch with the consumer protection agency to try toe get it fixed. I got an 01 ex 5speed what models do u guys have? Now I know what the noise is-thanks-honda told me it was a clutch plate or throwout bearing which was a bunch of bs because I changed all that and the flywheel(aftermarket of course) and I still have the noise. I got an 02 tranny sitting in the garage but want to get it fixed for free. If I can't is it worth it to fix it or just swap the 02 tranny in?
Old Sep 10, 2005
fixeruper's Avatar
i have a 04 lx-t with about 40,000 miles. yeah thats also a good ?
Old Sep 11, 2005
turboengnr's Avatar
DONT PANIC
my first tranny was an 02 lx
this tranny is an 01 ex
Old Sep 12, 2005
mradam85's Avatar
any idea of cost for relplacement? or a diy?
Old Sep 12, 2005
fixeruper's Avatar
better yet, a better than oem replacement
Old Sep 25, 2005
eziey's Avatar
eziey is an unknown quantity at this point
its not the axles. and if it clicks when you turn , its your cv joints. i know what your talkin about though , my cousin has the same noise in his civic. the noise comes from somewhere near the altinator
Old Sep 25, 2005
fixeruper's Avatar
no its coming from the trans and it happens all the time unless i compress the clutch
Old Sep 25, 2005
turboengnr's Avatar
DONT PANIC
That sounds like the input shaft bearing.
When i pull this motor out to put the built one in, i will be replacing the bearing in this tranny. I will try to remember to take pictures and write a DIY for replacing the bearing.
This DIY WILL NOT be for the beginner. I have already done it once, and it is a pain. It is much more complex than installing a turbo kit or installing a clutch. Simply due to the fact that you have to remove the gear cluster, the final drive, and the shifter assembly.
Old Oct 2, 2005
v8eaterokv6's Avatar
i have a new home do u
mine clicks but only when making a right hand turn at about 15-20 mph. it started after i installed my coilovers. when i was putting them in i dropped the right axel and it popped out of the transmission but i just slid it back in i think when this happend i might have broke something, any sugestions for this?
Old Oct 2, 2005
fixeruper's Avatar
its your axel, you broke it.
Old Oct 2, 2005
the cv joints dont leak and it doesnt klunk or anything like that just a ticking noise during the turn. i would think that if the axel was broke it would do more than just click.
carid
Sep 28, 2015 10:13 AM
Skunkone
Sep 24, 2015 04:38 PM
charmon4815
General
Sep 22, 2015 08:00 AM
Juanb24
Sep 15, 2015 12:39 AM
Josh 1973
Sep 7, 2015 10:10 AM
