What does this code mean?
Well your has to do with the CMP (TDC) having no signal. Just like any other issue, you either have a sensor problem, wiring problem, or problem with the ECU. Need to diagnose it to check.
Originally Posted by Michalo187
yeah its pluged in
the sensor on the side correct where the timing belt goes?
If your valve timing was off, you would know it. If it was off too much, you would have bent some valves and possibly caused some piston damage and your car wouldnt run. Anyway, either the sensor is bad, you have a wiring problem, or a problem with the ECU. you just have to diagnose the problem. When I get home from school today, I can go through the procedure with you to check the code if you have a DMM (digital mulitmeter available).
Civic15
18
Sep 19, 2017 07:48 PM
Dangerousjordan
Jul 30, 2015 11:19 AM
jessica19699
Jul 29, 2015 05:51 AM
Green02civic
Jul 27, 2015 10:48 PM
